coq-club - Re: [Coq-Club] About reductions of Fixpoint
chronological Thread
  • To: AUGER Cédric <Cedric.Auger AT lri.fr>
  • Cc: Daniel Schepler <dschepler AT gmail.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] About reductions of Fixpoint
  • Date: Wed, 08 Feb 2012 18:28:21 +0100
Hello Cedric,
reduction is designed in a way that it is strongly normalizing in arbitrary contexts.
On 2/8/12 10:08 AM, AUGER Cédric wrote:
Furthermore, in your example, the recursive call to "non_wf_not_wf"
is under a "match with", so it is already in head normal form; to fit
my examples,
  Fixpoint non_wf_not_wf (n:nat) (Hacc:Acc non_wf n)
    {struct Hacc} : False :=
  non_wf_not_wf (S n) match Hacc with
                      | Acc_intro f =>  f (S n) (non_wf_const n))
                      end.
would have been better; and shows a case where a fixpoint is a direct
application to itself (and thus breaking one of the comments on my
previous mail), but in fact, I don't see any case where you can define
fxpoints from non empty types to non empty types (in a consistent
environment) which is defined by a direct call to itself applied to
some wisely chosen parameters. I guess it is not possible, since it
seems such functions would be endlessly reduceable.
More reductions are safe in for closed terms, as you observe. To enable these consistently, one would have to carry around for each term whether it is closed. I am not sure the infrastructure for this is there in Coq.
On a somewhat related note, I've been wondering whether it would be
possible to add a reduction of
match (match a with
            | const1 =>  expr1
            | const2 =>  expr2
            end) with
| const1' =>  expr1'
| const2' =>  expr2'
end
to
match a with
| const1 =>  match expr1 with
   | const1' =>  expr1'
   | const2' =>  expr2'
   end
| const2 =>  match expr2 with
   | const1' =>  expr1'
   | const2' =>  expr2'
   end
end.
Hugo has a lot to say about these "commutative cuts", see p32 of his talk here:
  http://yquem.inria.fr/~herbelin/talks/cic.pdf
These reductions are difficult for dependent eliminations.
Cheers,
Andreas
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
