coq-club - [Coq-Club] string decidability
chronological Thread
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] string decidability
  • Date: Thu, 9 Feb 2012 10:59:33 +0100
Hello fellas,
I've a question about what looks like (to me at least :)) a weird behavior from string_dec.
Let's see, as expected the following typechecks properly:
(if string_dec s0 s0 then true else false) = false
So I would expect that,
assert (string_dec s0 s0 = true)
also would. However it yields: The term "true" has type "bool" while it is expected to have type "{s0 = s0} + {s0 <> s0}".
Furthermore, it looks like Coq is not able to compute the result of "string_dec s0 s0", to the fairly obvious answer true. (it's obvious... right? :))
This is surprising to me since I've been using the following function for quite a while now, and I never stumbled across such thing.
Definition beq_ident id1 id2 : bool :=
  match id1, id2 with
    | Ident str1, Ident str2    => match string_dec str1 str2 with
                                      | left _ => true
                                      | right _ => false
                                   end
  end.
Evaluating it, gives what one would expect....
Definition X := Ident "foo".
Definition Y := Ident "bar".
Definition f x y : bool := beq_ident x y.
Eval compute in f X Y.   (*yields false, as expected.*)
I would appreciate some lights in this subject please!
Just to give some context: I have the following hypothesis in my context, and I would expect that the tactic congruence would solve my goal, but no luck. I just assumed that I needed a simple simpl in H, but nope...I then started a few experiments with string_dec and got stuck.
H: (if string_dec s0 s0 then true else false) = false
Thank you.
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
