coq-club - Re: [Coq-Club] Problem defining a function using lexicographic combinations and then wf-annotation
chronological Thread
  • From: "Harley D. Eades III" <harley.eades AT gmail.com>
  • To: Arthur Chargu�raud <arthur AT chargueraud.org>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Problem defining a function using lexicographic combinations and then wf-annotation
  • Date: Sat, 17 Mar 2012 12:28:28 -0500
Hi Arthur,
2012/3/16 Arthur Charguéraud <arthur AT chargueraud.org>
Hi Harley,
If you are happy to use non-constructive definitions, you may use the "Optimal Fixed Point Combinator" for your definitions.
For the ackermann function, you can construct the fix point and then prove a fixed point equation that allows unfolding the body of the function when needed. My Coq script is as follows.
Definition Ack ack m n :=
  If m = 0 then n+1 else
  If n = 0 then ack (m-1) 1 else
  ack (m-1) (ack m (n-1)).
Definition ack := FixFun2 Ack.
Ltac emaths := eauto with maths.
Lemma fix_ack : forall m n,
  ack m n = Ack ack m n.
Proof.
  applys~ (FixFun2_fix (lexico2 (@lt nat _) (@lt nat _))).
  introv IH. unfolds. case_if~. case_if~.
  apply IH. emaths.
  rewrite IH. fequals~. emaths. emaths.
Qed.
You can find more details from: http://arthur.chargueraud.org/projects/fix/
I didn't know about this.  Thanks for the example and the link.  I don't think it will work for my purposes, but I will definitely remember it.
PS: If you need to remain constructive, you will probably need to use "Program Fixpoint" and give you definition a dependent type that captures enough of the specification of the function for you to be able to justify termination. I am not aware of any recursive functions for which the dependent-type approach is impossible to use.
Yes, this is what I ended up doing.  I do want to remain constructive.  I managed to get it defined use this and proving the obligations.  The only question I have is is it harder to reason about functions defined this way?
Thanks,
Harley
Hello.
I am trying to define a function using the well-founded annotation for function definitions.
Here is a simple example illustrating both my problem and what I am attempting:
Inductive ord : (nat * nat) -> (nat * nat) -> Prop :=
  | ord_red1 : forall n n' m m',
    n < m -> ord (n, n') (m, m')
  | ord_red2 : forall n n' m',
    n' < m' -> ord (n, n') (n, m').
Function ack (p : nat*nat) {wf ord p } : nat :=
  match p with
    | (0, n) => (S n)
    | (S m, 0) => ack (m,1)
    | (S m, S n) => ack(m, ack(S m, n))
  end.
Keep in mind that this is just an example.  The function I ultimately want to define is more complex
than this example.
The main problem is that the above function is rejected by Coq.  I believe it is because I am not allowed
to use nested recursive calls in the body of a function; as in the last branch of ack.
My question is, does anyone know of a way around this?  I really want to be able to use the well-founded annotation, because
the function I really want to define would be very difficult any other way.
In this case I might be able to use 'fix' to get around the above problem, but I am wondering if there are any other ways, because doing it using 'fix' essentially makes using the wf-annotation pointless.  Also, my ultimate goal is not possible using 'fix', at least I think it is.
If anyone wants to know what this "ultimate" function is I will post it.
Thanks,
Harley
