coq-club - [Coq-Club] Problem defining a function using lexicographic combinations and then wf-annotation
chronological Thread
  • From: "Harley D. Eades III" <harley.eades AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Problem defining a function using lexicographic combinations and then wf-annotation
  • Date: Fri, 16 Mar 2012 01:45:58 -0500
Hello.
I am trying to define a function using the well-founded annotation for function definitions.
Here is a simple example illustrating both my problem and what I am attempting:
Inductive ord : (nat * nat) -> (nat * nat) -> Prop :=
  | ord_red1 : forall n n' m m',
    n < m -> ord (n, n') (m, m')
  | ord_red2 : forall n n' m',
    n' < m' -> ord (n, n') (n, m').
Function ack (p : nat*nat) {wf ord p } : nat :=
  match p with
    | (0, n) => (S n)
    | (S m, 0) => ack (m,1)
    | (S m, S n) => ack(m, ack(S m, n))
  end.
Keep in mind that this is just an example.  The function I ultimately want to define is more complex
than this example.
The main problem is that the above function is rejected by Coq.  I believe it is because I am not allowed
to use nested recursive calls in the body of a function; as in the last branch of ack.
My question is, does anyone know of a way around this?  I really want to be able to use the well-founded annotation, because
the function I really want to define would be very difficult any other way.
In this case I might be able to use 'fix' to get around the above problem, but I am wondering if there are any other ways, because doing it using 'fix' essentially makes using the wf-annotation pointless.  Also, my ultimate goal is not possible using 'fix', at least I think it is.
If anyone wants to know what this "ultimate" function is I will post it.
Thanks,
Harley
