coq-club - Re: [Coq-Club] decreasing arg. on mutually recursive functions
chronological Thread
  • From: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • To: Nuno Gaspar <nmpgaspar AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] decreasing arg. on mutually recursive functions
  • Date: Tue, 20 Mar 2012 12:17:50 +0100
Hi,
In short, bad luck for you, you are the 134368th to face the situation where mutual fixpoints and inner fixpoints are not equivalent !
write
Fixpoint beq_a (x y:a) : bool :=
 match x, y with
   | A n lz, A n' lz' => (beq_nat n n') &&
((fix beq_list_a (l l': list a): bool :=
  match l, l' with
  | nil, nil         => true
  | cons e r, cons e' r' => (beq_a e e') && (beq_list_a r r')
  | _, _             => false
  end) lz lz')
 end.
and it's accepted.
Sorry for that
All the best.
Pierre
Le 20 mars 12 à 11:53, Nuno Gaspar a écrit :
Hello.
I want to define a boolean comparison function over the following inductive definition.
Inductive a : Type :=
  | A : nat -> list a -> a.
It's simple, two elements of type _a_ are equal if their projections are. Now, it seemed to me that the following mutually recursive function would do that...
Function beq_a (x y:a) { ? } : bool :=
 match x, y with
   | A n lz, A n' lz' => (beq_nat n n') && (beq_list_a lz lz')
 end
with beq_list_a (l l': list a) {struct l}: bool :=
  match l, l' with
  | nil, nil         => true
  | e :: r, e' :: r' => (beq_a e e') && (beq_list_a r r')
  | _, _             => false
  end.
Coq requires the decreasing argument to be specified. However, in this mutually recursive definition I do not know how to specify it for [beq_a]. I guess this issue arises due to the fact that the functions pattern-match on different types ..
So, how can I convince Coq? :-)
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
