coq-club - Re: [Coq-Club] decreasing arg. on mutually recursive functions
chronological Thread
  • From: "Harley D. Eades III" <harley.eades AT gmail.com>
  • To: Nuno Gaspar <nmpgaspar AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] decreasing arg. on mutually recursive functions
  • Date: Tue, 20 Mar 2012 06:22:47 -0500
Hi, Nuno.  You need to use a Fixpoint.  Your function is decreasing lexicographically.
Here is the easiest way to do it:
Inductive a : Type :=
  | A : nat -> list a -> a.
Fixpoint beq_a (x y:a) : bool :=
  match x, y with
    | A n lz, A n' lz' =>
      let aux := (fix beq_list_a (l l': list a) :=
        match l, l' with
          | nil, nil         => true
          | e :: r, e' :: r' => andb (beq_a e e') (beq_list_a r r')
          | _, _             => false
        end) in andb (beq_nat n n') (aux lz lz')
  end.
I hope this helps.
Harley
On Tue, Mar 20, 2012 at 5:53 AM, Nuno Gaspar <nmpgaspar AT gmail.com> wrote:
Hello.
I want to define a boolean comparison function over the following inductive definition.
It's simple, two elements of type _a_ are equal if their projections are. Now, it seemed to me that the following mutually recursive function would do that...
Function beq_a (x y:a) { ? } : bool :=
 match x, y with
   | A n lz, A n' lz' => (beq_nat n n') && (beq_list_a lz lz')
 end
with beq_list_a (l l': list a) {struct l}: bool :=
  match l, l' with
  | nil, nil         => true
  | e :: r, e' :: r' => (beq_a e e') && (beq_list_a r r')
  | _, _             => false
  end.
Coq requires the decreasing argument to be specified. However, in this mutually recursive definition I do not know how to specify it for [beq_a]. I guess this issue arises due to the fact that the functions pattern-match on different types ..
So, how can I convince Coq? :-)
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
