- To: <matthieu.sozeau AT gmail.com>
- Cc: coq club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Ltac unify expressions
- Date: Tue, 20 Mar 2012 20:32:08 +0100
- Importance: Normal
Hi,
I'm interested in this tactic, I tried to use it to unify two terms but unfortunately I get Error. Here is an example (well I know that there is an easier way to proved but i give it just as an example): Ltac unification_hyp := match goal with |[_ : ?t = ?u |- ?tg = ?ug ] => unify t tg | _ => fail end. Theorem th_exp : forall n : nat, n + 0 = n -> 0 + 0 = 0 . intros. unification_hyp. (*Error: No matching clauses for match goal (use "Set Ltac Debug" for more info).*) Thanks, Amira > From: matthieu.sozeau AT gmail.com > Date: Sat, 18 Feb 2012 01:49:09 +0100 > CC: gmalecha AT cs.harvard.edu > To: coq-club AT inria.fr > Subject: Re: [Coq-Club] Ltac unify expressions > > Hi Gregory, > > there is an undocumented tactic [unify x y [with hintdb]] that > does exactly what you expect. And it's now documented in the > reference manual. > -- Matthieu > > Le 17 févr. 2012 à 23:49, Adam Chlipala a écrit : > > > OK, perhaps then this to avoid adding unused cruft to proof terms: > > (let unused := (refl_equal _ : a = b) in k true) || k false > > > > As for avoiding CPS, nothing comes to mind yet. > > > > On 02/17/2012 05:45 PM, Gregory Malecha wrote: > >> Does the [clear] call remove all traces of this from the proof? I'm going to end up calling this a lot (at least 100) and I'm worried about even small bits being left in the proof. > >> > >> The other thing is that this means is that I have to cps convert all of my ltac. Is there any other way to do this? I assume there is some Ocaml function that I could expose using a plugin if this doesn't exist right now. Would this be reasonable? > >> > >> Thanks. > >> > >> On Fri, Feb 17, 2012 at 5:26 PM, Adam Chlipala <adamc AT csail.mit.edu> wrote: > >> On 02/17/2012 04:44 PM, Gregory Malecha wrote: > >>> I am wondering if there is a better way to perform semantic equivalence checking in Ltac. Currently, I'm doing the following: > >>> > >>> Ltac unifies a b := > >>> match a with > >>> | b => true > >>> | _ => > >>> let a := eval cbv in a in > >>> let b := eval cbv in b in > >>> match a with > >>> | b => true > >>> | _ => false > >>> end > >>> end. > >> > >> Here's one of those Gallina/Ltac puns that is both horrifying and super-fun IMO: > >> (let H := fresh in assert (H : a = b) by reflexivity; clear H; (* call a continuation with [true]) || (* call continuation with [false] *) > >> This may have side effects if there are unification variables left undetermined beforehand. > >> > > > > |
- RE: [Coq-Club] Ltac unify expressions, henaien amira
- Re: [Coq-Club] Ltac unify expressions,
Gregory Malecha
henaien amira
- Message not available
henaien amira
Beta Ziliani
henaien amira
- Re: [Coq-Club] Ltac unify expressions, Kristopher Micinski
- Re: [Coq-Club] Ltac unify expressions, Jonas Oberhauser
henaien amira
Beta Ziliani
henaien amira
henaien amira
Gregory Malecha
