- To: <krismicinski AT gmail.com>
- Cc: <beta AT mpi-sws.org>, coq club <coq-club AT inria.fr>
- Subject: RE: [Coq-Club] Ltac unify expressions
- Date: Wed, 21 Mar 2012 14:39:59 +0100
- Importance: Normal
1. id_0 = n 2. id_s (n0 ) = n But I want to have this : 1. id_0 = id_0 2. id_s (plus n0 id_0) = id_s n0 > Date: Wed, 21 Mar 2012 09:25:37 -0400 > From: krismicinski AT gmail.com > To: henaien_amira AT hotmail.com > CC: beta AT mpi-sws.org; coq-club AT inria.fr > Subject: Re: [Coq-Club] Ltac unify expressions > > wait, why can't you just destruct on something involving plus, then? > > kris > > On Wed, Mar 21, 2012 at 9:21 AM, henaien amira > <henaien_amira AT hotmail.com> wrote: > > "Case n" will do case analysis by following the definition of type of n > > (here nat ) but in my work I need a case analysis following the definition > > of the function : "plus". > > > > > > > > ________________________________ > > From: beta AT mpi-sws.org > > Date: Wed, 21 Mar 2012 13:42:07 +0100 > > To: henaien_amira AT hotmail.com > > CC: coq-club AT inria.fr > > > > Subject: Re: [Coq-Club] Ltac unify expressions > > > > I'm still unsure of what you want to do, but I think that the tactic "case" > > is what you need here. > > > > If you do > > > > case n. > > > > you will get the exact result you described. > > > > Best, > > Beta > > > > On Wed, Mar 21, 2012 at 11:02 AM, henaien amira <henaien_amira AT hotmail.com> > > wrote: > > > > Hi Beta, > > > > Well, I take a look in Matita's home page and it seems that you are right. > > Actually I'm working in something similar: the implementation of an > > interactive theorem prover in Coq. But I have some difficulties with some > > rules. For example I have an inference rule which should take a function and > > an equality and give a case analysis of this last one. For example if I have > > the function plus : > > > > Fixpoint plus (x y : nat ) : nat := > > match x with > > | id_0 => y > > | id_s x' => id_s ( plus x' y) > > end. > > > > And if I have a theorem : > > > > Theorem th : forall n : nat , plus n id_0 = n. > > intro n . > > =========== > > plus n id_0 = n > > > > in this state my rule should give two subgoals : > > 1. plus id_0 id_0 = id_0 > > 2. id_s (plus n id_0) = id_s n > > > > I have tried the tactic destruct plus. but destruct works only in the first > > part so I'm looking for a tactic that may give the substitution used in the > > first part of the equality so I can applied it for the second one. Or it > > will great if there is a tactic that my do the case analysis. > > > > I hope that I have explained enough to get help :) . > > > > Thanks, > > > > Amira > > > > ________________________________ > > From: beta AT mpi-sws.org > > Date: Wed, 21 Mar 2012 09:33:14 +0100 > > > > Subject: Re: [Coq-Club] Ltac unify expressions > > To: henaien_amira AT hotmail.com > > > > > > Hi Amira, > > > > I'm curious about the use for such tactic. Can you tell me more about your > > idea? The reason why I'm asking is because I have the impression that it > > would be useful to have explicit meta-variables like Matita[1] does. And > > your problems seems to fit into this concept. > > > > Cheers, > > Beta > > > > [1] Table 4.10 in > > http://matita.cs.unibo.it/docs/manual/html/sec_terms.html#terms_and_co > > > > > > > > On Wed, Mar 21, 2012 at 9:03 AM, henaien amira <henaien_amira AT hotmail.com> > > wrote: > > > > > > Hi Malecha, > > > > Think you very much for responding me. So, Unify will not be helpful to me. > > And as I say in my question, the example is just to illustrate. Actually > > what I wish to get is the substitution that will be applied by the tactic > > "apply" if it was used. > > > > > > ________________________________ > > From: gmalecha AT eecs.harvard.edu > > Date: Tue, 20 Mar 2012 17:19:43 -0400 > > To: henaien_amira AT hotmail.com > > CC: matthieu.sozeau AT gmail.com; coq-club AT inria.fr > > > > Subject: Re: [Coq-Club] Ltac unify expressions > > > > Hi, Henaien -- > > > > This tactic is not meant do do what you are asking it to do. This tactic > > only checks that the two terms are equal to each other (where equal is Coq's > > equal, i.e. beta, delta, iota, zeta equivalence). This isn't the case for > > your term because > > > > n + 0 > > > > does not reduce to > > > > 0 + 0 > > > > What you need to do here is pick a particular [n] to instantiate with. I > > think you are meaning your lemma to be phrased as: > > > > Theorem th_exp : (forall n : nat, n + 0 = n) -> 0 + 0 = 0. > > > > This would be solved by > > > > intro H; apply H. > > > > or [auto]. > > > > Hope this helps. > > > > On Tue, Mar 20, 2012 at 3:32 PM, henaien amira <henaien_amira AT hotmail.com> > > wrote: > > > > Hi, > > > > I'm interested in this tactic, I tried to use it to unify two terms but > > unfortunately I get Error. Here is an example (well I know that there is an > > easier way to proved but i give it just as an example): > > > > Ltac unification_hyp := > > match goal with > > |[_ : ?t = ?u |- ?tg = ?ug ] => unify t tg > > | _ => fail > > end. > > > > Theorem th_exp : forall n : nat, n + 0 = n -> 0 + 0 = 0 . > > intros. > > unification_hyp. (*Error: No matching clauses for match goal (use "Set Ltac > > Debug" for more info).*) > > > > > > Thanks, > > > > Amira > > > > > >> From: matthieu.sozeau AT gmail.com > >> Date: Sat, 18 Feb 2012 01:49:09 +0100 > >> CC: gmalecha AT cs.harvard.edu > >> To: coq-club AT inria.fr > >> Subject: Re: [Coq-Club] Ltac unify expressions > > > >> > >> Hi Gregory, > >> > >> there is an undocumented tactic [unify x y [with hintdb]] that > >> does exactly what you expect. And it's now documented in the > >> reference manual. > >> -- Matthieu > >> > >> Le 17 févr. 2012 à 23:49, Adam Chlipala a écrit : > >> > >> > OK, perhaps then this to avoid adding unused cruft to proof terms: > >> > (let unused := (refl_equal _ : a = b) in k true) || k false > >> > > >> > As for avoiding CPS, nothing comes to mind yet. > >> > > >> > On 02/17/2012 05:45 PM, Gregory Malecha wrote: > >> >> Does the [clear] call remove all traces of this from the proof? I'm > >> >> going to end up calling this a lot (at least 100) and I'm worried about even > >> >> small bits being left in the proof. > >> >> > >> >> The other thing is that this means is that I have to cps convert all of > >> >> my ltac. Is there any other way to do this? I assume there is some Ocaml > >> >> function that I could expose using a plugin if this doesn't exist right now. > >> >> Would this be reasonable? > >> >> > >> >> Thanks. > >> >> > >> >> On Fri, Feb 17, 2012 at 5:26 PM, Adam Chlipala <adamc AT csail.mit.edu> > >> >> wrote: > >> >> On 02/17/2012 04:44 PM, Gregory Malecha wrote: > >> >>> I am wondering if there is a better way to perform semantic > >> >>> equivalence checking in Ltac. Currently, I'm doing the following: > >> >>> > >> >>> Ltac unifies a b := > >> >>> match a with > >> >>> | b => true > >> >>> | _ => > >> >>> let a := eval cbv in a in > >> >>> let b := eval cbv in b in > >> >>> match a with > >> >>> | b => true > >> >>> | _ => false > >> >>> end > >> >>> end. > >> >> > >> >> Here's one of those Gallina/Ltac puns that is both horrifying and > >> >> super-fun IMO: > >> >> (let H := fresh in assert (H : a = b) by reflexivity; clear H; (* call > >> >> a continuation with [true]) || (* call continuation with [false] *) > >> >> This may have side effects if there are unification variables left > >> >> undetermined beforehand. > >> >> > >> > > >> > >> > > > > > > > > > > -- > > gregory malecha > > http://www.people.fas.harvard.edu/~gmalecha/ > > > > > > > |
- RE: [Coq-Club] Ltac unify expressions, henaien amira
- Re: [Coq-Club] Ltac unify expressions,
Gregory Malecha
henaien amira
- Message not available
henaien amira
Beta Ziliani
henaien amira
- Re: [Coq-Club] Ltac unify expressions, Kristopher Micinski
- Re: [Coq-Club] Ltac unify expressions, Jonas Oberhauser
henaien amira
Beta Ziliani
henaien amira
henaien amira
Gregory Malecha
