coq-club - [Coq-Club] Some problems about type 'Set'
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Some problems about type 'Set'
  • Date: Wed, 21 Mar 2012 16:07:29 +0800 (CST)
Hi guys,
  We meet some problems when using type 'Set'. We think the lemmas are quiet intuitive, any suggestion is appreciated.
Require Export String Bool ListSet List Arith Compare_dec Coq.Unicode.Utf8.
Open Scope nat_scope.
Open Scope type_scope.
Open Scope string_scope.
Inductive Kind:Set:=
|Send:Kind
|Receive:Kind.
Notation "!":=Send (at level 40).
Notation "?":=Receive (at level 40).
Definition Signal:=nat.
Definition Lifeline:=nat.
Definition Message:=Signal*Lifeline*Lifeline.
Definition Event:=Kind*Message.
Definition beq_lifeline (l1:Lifeline)(l2:Lifeline):bool:=
  beq_nat l1 l2.
Fixpoint projLife (l:Lifeline) (se: set Event) : set Event :=
match se with
|nil =>nil
|e::etail => match e with
           |(!,m) => match m with (_,tr,re) => if (beq_lifeline tr l)
                              then e::(projLife l etail)
                              else (projLife l etail)
                              end
           |(?,m) => match m with (_,tr,re) => if (beq_lifeline re l)
                              end
           end
end.
(*Q1:We believe this lemma holds,but we get lost when destructing the event*)
Lemma EventsEqualproj:forall s1 s2, ( ∀e : Event, set_In e s1 ↔ set_In e s2)
                                 ->  (∀e' l, set_In e' (projLife l s1) ↔ set_In e' (projLife l s2)).
  intros;split;intros.
  destruct s1. inversion H0.
  destruct e. destruct k.
  simpl in H0. destruct m. destruct p. destruct (beq_lifeline l1 l).
(*Q2: Is there any lemma in the standard library of Coq to solve the following problem?  *)
Lemma setneg:forall s1 s2,( ∀e : Event, set_In e s1 ↔ set_In e s2) -> (( ∀e : Event, ¬set_In e s1 ↔ ¬set_In e s2)).
Best Regards,
Phoebe
