coq-club - Re: [Coq-Club] Some problems about type 'Set'
chronological Thread
  • To: 左樱 <phoebezz AT 163.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Some problems about type 'Set'
  • Date: Wed, 21 Mar 2012 09:10:26 -0400
Your [projLife] is just an instance of the standard list higher-order function [filter], and we can use a theorem about [filter] from the standard library to do almost all of the work. Here's my alternate code, which replaces your code starting with the definition of [projLife]:
Definition projLife (l : Lifeline) : set Event -> set Event :=
  filter (fun e => let '(k, (_, tr, re)) := e in
    beq_lifeline (match k with
                    | ! => tr
                    | ? => re
                  end) l).
(*Q1:We believe this lemma holds,but we get lost when destructing the event*)
Lemma EventsEqualproj:forall s1 s2, ( ∀e : Event, set_In e s1 ↔ set_In e s2)
-> (∀e' l, set_In e' (projLife l s1) ↔ set_In e' (projLife l s2)).
  unfold projLife; intros until l; split; intro Hin;
    apply filter_In in Hin; apply filter_In; firstorder.
Qed.
(*Q2: Is there any lemma in the standard library of Coq to solve the following problem? *)
Lemma setneg:forall s1 s2,( ∀e : Event, set_In e s1 ↔ set_In e s2) -> (( ∀e : Event, ¬set_In e s1 ↔ ¬set_In e s2)).
  firstorder.
Qed.
