- To: Jelle Herold <jelle AT defekt.nl>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Building coqdep for VV patched Coq
- Date: Mon, 26 Mar 2012 10:40:54 -0400
I do not know how to answer your question but just one comment on the whole
situation. The reason patched coq does not build with the usual make is that
the compilation of some of the standard library files hangs. This is in turn
caused by the patch which switches off sharing in the computation algorithm
which makes some of the computations/normalizations used in the standard
library very very slow.
This patch was and is intended as a temporary measure until someone fixes a
bug in the sharing algorithm which leads to the hanging of the system in some
other situations which occur in the Univalent library. I know that both Hugo
and George and probably many others are aware of this bug. May be it's time
to have it fixed?
Vladimir.
On Mar 26, 2012, at 10:24 AM, Jelle Herold wrote:
> Hello,
> To work with Vladimir Voevodsky's code you need a patched Coq. Once
> patched, it is suggested[1] Coq is build using:
> make GOTO_STAGE=2 coqbinaries states
> make install
> (building without GOTO_... fails)
> While this works there are two problems:
> 1) coqdep is not build, coqdep_boot is there, but that seems not to be
> the same thing...?
> 2) coqc.opt is build, but not the coqc binary/symlink
> The 2nd is not such a big deal, but can I somehow build coqdep?
> [1]
> https://github.com/vladimirias/Foundations/blob/master/Coq_patches/README
> Any thoughts?
> Thanks a lot,
> Jelle.
> PS. Here is a script that builds coq as described.
> #! /bin/sh
> # shell script to compile and patch coq for HoTT work
> set +x
> git clone https://github.com/vladimirias/Foundations.git
> curl -L http://coq.inria.fr/distrib/8.3pl2/files/coq-8.3pl2.tar.gz | tar
> xzvf -
> #tar xjvf coq-8.3pl2.tbz
> cd coq-8.3pl2
> ./configure -with-doc no -local #-coqide no
> ln -s ../Foundations/Coq_patches patches
> patch -p1 < patches/inductive-indice-levels-matter-8.3.patch
> patch -p3 < patches/patch.type-in-type
> patch -p0 < patches/fix-hanging-at-end-of-proof.patch
> patch -p0 < patches/grayson-fix-infinite-loop.patch
> patch -p0 < patches/grayson-improved-abstraction-version2-8.3pl2.patch
> patch -p0 < patches/grayson-closedir-after-opendir.patch
> time make GOTO_STAGE=2 coqbinaries states
> time make install
- [Coq-Club] Building coqdep for VV patched Coq, Jelle Herold
- Re: [Coq-Club] Building coqdep for VV patched Coq, Vladimir Voevodsky
