- To: "Edward Z. Yang" <ezyang AT mit.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq prompt in proof-general
- Date: Sun, 08 Apr 2012 13:53:12 +0100
Hi Edward,
Thanks, I am using emacs because I use it for just about everything!
Besides I have lots of kbd macros defined for various utf8 characters
etc. I only need the *coq* buffer occasionally, e.g. for informally
testing a Fixpoint, so I think I will just have to live with the messy
prompt!
On Fri, 2012-04-06 at 21:39 -0400, Edward Z. Yang wrote:
> Hello Benard,
> You can use the 'coqtop' executable directly, which will give a nicer
> prompt. Unfortunately, ProofGeneral needs this gunk because it needs
> to parse out goal information (so it passes -emacs-U to the process.)
> Edward
> Excerpts from bernard's message of Fri Apr 06 21:14:47 -0400 2012:
> > Hi all,
> > I am using coq with prof-general in emacs. In the *coq* buffer the prompt
> > looks like:
> > <prompt>Coq < 25 || 0 < </prompt>
> > What can I do to clean it up?
> > Thanks,
> > Bernard
- [Coq-Club] coq prompt in proof-general, Bernard Hurley
- Re: [Coq-Club] coq prompt in proof-general,
Edward Z. Yang
- Re: [Coq-Club] coq prompt in proof-general, Bernard Hurley
Adam Chlipala
- Re: [Coq-Club] coq prompt in proof-general, Pierre Courtieu
Adam Chlipala
Edward Z. Yang
