coq-club - Re: [Coq-Club] coq prompt in proof-general
chronological Thread
  • To: Bernard Hurley <bernard AT marcade.biz>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coq prompt in proof-general
  • Date: Sun, 08 Apr 2012 09:03:24 -0400
I suggest entering "test" code in a regular buffer to run it. You can just undo and delete it right afterward.
Bernard Hurley wrote:
Thanks, I am using emacs because I use it for just about everything!
Besides I have lots of kbd macros defined for various utf8 characters
etc. I only need the *coq* buffer occasionally, e.g. for informally
testing a Fixpoint, so I think I will just have to live with the messy
prompt!
On Fri, 2012-04-06 at 21:39 -0400, Edward Z. Yang wrote:
Hello Benard,
You can use the 'coqtop' executable directly, which will give a nicer
prompt.  Unfortunately, ProofGeneral needs this gunk because it needs
to parse out goal information (so it passes -emacs-U to the process.)
Edward
Excerpts from bernard's message of Fri Apr 06 21:14:47 -0400 2012:
Hi all,
I am using coq with prof-general in emacs.  In the *coq* buffer the prompt
looks like:
<prompt>Coq<  25 || 0<  </prompt>
What can I do to clean it up?
Thanks,
Bernard
