- To: "BAILEY C. (527272)" <C.BAILEY.527272 AT swansea.ac.uk>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Quicksort algorithm using Coq
- Date: Tue, 10 Apr 2012 10:07:39 -0400
On Sun, 8 Apr 2012 15:31:30 +0000, "BAILEY C. (527272)"
wrote:
> Hi, I am currently writing a thesis about program verification in the coq
> system with the main goal being focused on the quicksort algorithm.
> First of all thank you for all of your work that you have done concerning
> Coq as it has helped me extensively. Secondly I was wondering if I may use
> your help to do the last part of my quicksort proof. I have done my
> implementation slightly differently to how most people have tackled the
> quicksort problem before myself. So far I have defined the quicksort, now
> as the next step I need to actually proof the algorithm using tactics which
> is where I find myself to be slightly stuck. I'm not really sure where to
> start to actually proof this and was wondering if you would be so kind as
> to help please.
I haven't looked at your code, but are you familiar with
<http://weegen.home.xs4all.nl/eelis/research/quicksort/>?
Also, you are probably more likely to get a useful response if you
indicate which particular part you are having trouble with. In
particular, I don't see any proof here at all.
Tom
- [Coq-Club] Quicksort algorithm using Coq, BAILEY C. (527272)
- Re: [Coq-Club] Quicksort algorithm using Coq, Tom Prince
