coq-club - [Coq-Club] Quicksort algorithm using Coq
chronological Thread
  • From: "BAILEY C. (527272)" <C.BAILEY.527272 AT swansea.ac.uk>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] Quicksort algorithm using Coq
  • Date: Sun, 8 Apr 2012 15:31:30 +0000
  • Accept-language: en-GB, en-US
Hi, I am currently writing a thesis about program verification in the coq system with the main goal being focused on the quicksort algorithm.
First of all thank you for all of your work that you have done concerning Coq as it has helped me extensively. Secondly I was wondering if I may use your help to do the last part of my quicksort proof. I have done my implementation slightly differently to how most people have tackled the quicksort problem before myself. So far I have defined the quicksort, now as the next step I need to actually proof the algorithm using tactics which is where I find myself to be slightly stuck. I'm not really sure where to start to actually proof this and was wondering if you would be so kind as to help please.
The following is what I have done so far:
Inductive nat : Type :=
   | O : nat
   | S : nat -> nat.
Check (S (S (S (S O)))).
Definition isZero (n:nat) : bool :=
  match n with
   O => true
  |S p => false
  end.
Inductive List: Set :=
 | nil: List
 | cons: nat -> List -> List.
Fixpoint Concat (L R: List) : List :=
 match L with
 | nil => R
 | cons l ls => cons l (Concat ls R)
end.
Fixpoint Less (n m:nat) :=
  match m with
   O => false
  |S q => match n with
          O => true
         |S p => Less p q
         end
  end.
Fixpoint Lesseq (n m:nat) :=
  match n with
   O => true
  |S p => match m with
           O => false
          |S q => Lesseq p q
          end
  end.
Fixpoint Greatereq (n m:nat) :=
  match n with
   O => true
           O => true
          |S q => Greatereq p q
          end
  end.
Fixpoint Allless (l:List) (n:nat) : List :=
  match l with
   nil => nil
  |cons m ls => match Less n m with
                 false => Allless ls n
                |true => cons m (Allless ls n)
                end
end.
Fixpoint Allgeq (l:List) (n:nat) : List :=
  match l with
   nil => nil
  |cons m ls => match Greatereq n m with
                 false => Allgeq ls n
                |true => cons m (Allgeq ls n)
                end
end.
Fixpoint qaux (n:nat) (l:List) : List :=
  match n with
  O => nil
 |S p => match l with
         nil => nil
        |cons m ls => let low := Allless ls m in
                     (let high := Allgeq ls m in
                     Concat (qaux p low) (cons m (qaux p high)))
        end
 end.
Fixpoint length (l:List) : nat :=
 match l with
  nil => O
|cons m ls => S (length ls)
end.
Fixpoint Quicksort (l:List) : List := qaux (length l) l.
Hopefully you can help and thank you very much for your time.
Regards,
Callum Bailey.
