coq-club - History of backward application |> [Re: [Coq-Club] slicing along the statement of theorem]
chronological Thread
  • To: Makarius <makarius AT sketis.net>
  • Cc: coq-club AT inria.fr
  • Subject: History of backward application |> [Re: [Coq-Club] slicing along the statement of theorem]
  • Date: Sat, 14 Apr 2012 23:21:39 +0200
Thanks, Makarius, for that history lesson! I had been looking for a reference a couple of times before, unsuccessfully.
You can count me to the fans of |>, I have added it to my language MiniAgda some months ago.
  http://www2.tcs.ifi.lmu.de/~abel/miniagda
[Digression:
SML's case-of statement is superfluous if you have |>, because instead of
  case e of
     p1 => t1
   | p2 => t2
you can just write
  e |> fn p1 => t1
        | p2 => t2
(This is more useful for >>= than for |>, see below.)
End of Digression.]
I have also added <| for ordinary application, but frankly, I am more used to Haskell's $.
Regarding the "extremism of the Haskell community", aeh, I think that all kinds of application and composition operators, just to mention
are quite helpful I you have to program with explicit monads and applicative functors.
Unfortunately, Haskell is missing "fn", thus instead of
  e >>= fn p1 -> t1
           p2 -> t2
I have to introduce an auxiliary variable and write
  x <- e
  case e of
    p1 -> t1
    p2 -> t2
Cheers,
Andreas
P.S.:
On 13.04.12 12:26 PM, Makarius wrote:
On Fri, 13 Apr 2012, Stéphane Glondu wrote:
Le 12/04/2012 19:30, Xavier Leroy a écrit :
Short form: is there a tool / how would you go about writing a tool
that, given the *statement* of a Coq theorem, shows all *definitions*
involved in this statement, omitting all the stuff that contribute
only to the *proof* of the theorem?
This can be done in a plugin. I've attached a proof of concept.
Stéphane seems to like the |> operator, which was intruced in
Isabelle/ML in 1994 and later made its way into F#. See also
http://blogs.msdn.com/b/dsyme/archive/2011/05/17/archeological-semiotics-the-birth-of-the-pipeline-symbol-1994.aspx
Over the years, a few more variants of it were introduced that could
also help OCaml and Coq people to express function application and
composition concisely, without the extremism of the Haskell community in
this respect.
This is the essential starter kit in OCaml notation:
let (|>) x f = f x
let (|->) (x, y) f = f x y
I think I have seen
  let (||>) (x,y) f = f x y
then you can continue
  let (|||>) (x,y,z) = f x y z
etc.
let (@>) f g x = g (f x)
let (@->) f g (x, y) = g (f x y)
The latter two are called #> and #-> in Isabelle/ML, but OCaml does not
allow # in symbolic identifiers as it seems.
Makarius
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
