coq-club - [Coq-Club] Should this be obvious?
chronological Thread
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Should this be obvious?
  • Date: Sat, 21 Apr 2012 04:13:53 +0100
Hi,
I have a feeling this question might have an obvious answer, but I can't
see what it is!
After this code, which is adapted from Adam Chlipala's book:
Inductive type : Set := Nat | Bool.
Definition tstack := list type.
Definition typeDenote (t : type) : Set :=
  match t with
    | Nat => nat
    | Bool => bool
  end.
Fixpoint vstack (ts : tstack) : Set :=
  match ts with
    | nil => unit
    | t :: ts' => typeDenote t * vstack ts'
  end%type.
it seems logical to me that one ought to be able to construct an object
of data type  [vstack (Nat :: Bool :: Nat :: nil)] that corresponds in
the "obvious" way to the sequence (2, true, 7). However I can't see how
this could be done. How could it be done?
Regards,
Bernard.
