- From: "gallais @ ensl.org" <(e29315a54f%hidden_head%e29315a54f)guillaume.allais(e29315a54f%hidden_at%e29315a54f)ens-lyon.org(e29315a54f%hidden_end%e29315a54f)>
- To: Nuno Gaspar <(e29315a54f%hidden_head%e29315a54f)nmpgaspar(e29315a54f%hidden_at%e29315a54f)gmail.com(e29315a54f%hidden_end%e29315a54f)>
- Cc: coq-club <(e29315a54f%hidden_head%e29315a54f)coq-club(e29315a54f%hidden_at%e29315a54f)inria.fr(e29315a54f%hidden_end%e29315a54f)>
- Subject: Re: [Coq-Club] functions with accumulators
- Date: Sun, 13 May 2012 22:38:30 +0100
Hi Nuno,
When you are dealing with an auxiliary function using an
accumulator, it's a safe bet to assume that you need two
theorems: a really general one which deals with a non
empty acc and its corollary which is the statement you
are looking for.
See in the attached file how [fact] is a trivial instance of
[more_general_fact].
Cheers,
guillaume
On 13 May 2012 22:06, Nuno Gaspar
wrote:
> Hello.
> Consider the following trivial definitions:
> Inductive X : Type := Const: nat -> X.
> Definition projX (x:X) : nat :=
> match x with
> | Const n => n
> end.
> Function f (l:list X) (id:nat) (acc:list X) {struct l} : option (X * list
> X) :=
> match l with
> | nil => None
> | c :: r => if beq_nat (projX c) id then Some ((c, r :: acc)) else f r
> id (c :: acc)
> end.
> The above function simply looks for an element whose projection is equal to
> the given id. The problem arises due to the use of an accumulator - it will
> yield a weird induction hypothesis..
> For instance, in this following lemma
> Lemma fact:
> forall l id X c r,
> f l id X = Some (c,r) ->
> X = nil -> (*there's a reason for not directly including 'nil' in the
> function call above, but can be ignored for this question...*)
> forall x, In x l <-> In x (c :: r).
> Proof.
> intros.
> functional induction f l id X0; inversion H; subst; clear H.
> Case "branch true".
> admit. (*trivially true*)
> Case "branch false".
> (*weird induction hyp*)
> Qed.
> The induction hypothesis generated for the branch with the recursive call is
> as follows:
> IHo : f r0 id (c0 :: nil) = Some (c, r) ->
> c0 :: nil = nil ->
> (In x r0 <-> In x (c :: r))
> This, of course, doesn't help much..
> The first thing that I taught was to define my own induction principle, but
> i'm wondering if I am missing a terribly easier approach to solve the above
> lemma (and many of the like..)?
> Or more generally, how do guys go about reasoning on functions with
> accumulators?
> Thank you!
> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
> dollars last year.
> Marge: Bart! Don't make fun of grad students, they just made a terrible life
> choice.
facts_with_accs.v
Description: Binary data
- [Coq-Club] functions with accumulators, Nuno Gaspar, 05/13/2012
- Re: [Coq-Club] functions with accumulators, julien forest, 05/13/2012
- Re: [Coq-Club] functions with accumulators, gallais @ ensl.org, 05/13/2012
