coq-club - [Coq-Club] functions with accumulators
  • From: Nuno Gaspar <(e29315a54f%hidden_head%e29315a54f)nmpgaspar(e29315a54f%hidden_at%e29315a54f)gmail.com(e29315a54f%hidden_end%e29315a54f)>
  • To: coq-club <(e29315a54f%hidden_head%e29315a54f)coq-club(e29315a54f%hidden_at%e29315a54f)inria.fr(e29315a54f%hidden_end%e29315a54f)>
  • Subject: [Coq-Club] functions with accumulators
  • Date: Sun, 13 May 2012 23:06:11 +0200
Hello.
Consider the following trivial definitions:
Inductive X : Type := Const: nat -> X.
Definition projX (x:X) : nat :=
  match x with
    | Const n => n
  end.
Function f (l:list X)  (id:nat) (acc:list X) {struct l} : option (X * list X) :=
  match l with
    | nil    => None
    | c :: r => if beq_nat (projX c) id then Some ((c, r :: acc)) else f r id (c :: acc)
  end.
The above function simply looks for an element whose projection is equal to the given id. The problem arises due to the use of an accumulator - it will yield a weird induction hypothesis..
For instance, in this following lemma
Lemma fact:
  forall l id X c r,
  f l id X = Some (c,r) ->
  X = nil ->    (*there's a reason for not directly including 'nil' in the function call above, but can be ignored for this question...*)
  forall x, In x l <-> In x (c :: r).
Proof.
  intros.
  functional induction f l id X0; inversion H; subst; clear H.
  Case "branch true".
    admit. (*trivially true*)
  Case "branch false".
    (*weird induction hyp*)
Qed.
The induction hypothesis generated for the branch with the recursive call is as follows:
IHo : f r0 id (c0 :: nil) = Some (c, r) ->
        c0 :: nil = nil ->
        (In x r0 <-> In x (c :: r))
This, of course, doesn't help much..
The first thing that I taught was to define my own induction principle, but i'm wondering if I am missing a terribly easier approach to solve the above lemma (and many of the like..)?
Or more generally, how do guys go about reasoning on functions with accumulators?
Thank you!
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
