- To: Coq-Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Trouble with a recursive definition
- Date: Thu, 24 May 2012 07:15:35 -0700
- Importance: Normal
I have entered the following to define an abstract _expression_ type and a simple equality operator between expressions:
Inductive absExp ( f : id -> list ExpValue -> ExpValue ) : Type :=
| AbsNatVal : nat -> absExp f
| AbsHeapVal : heap -> absExp f
| AbsVar : id -> absExp f
| AbsQVar : absVar -> absExp f
| AbsFun : id -> list (absExp f) -> absExp f.
Fixpoint beq_absExp_list x (e1 : list (absExp x)) (e2 : list (absExp x)) : bool :=
match e1 with
| nil => match e2 with nil => true | _ => false end
| (AbsNatVal v)::r1 => match e2 with (AbsNatVal v2)::r2 => if beq_nat v v2 then beq_absExp_list x r1 r2 else false | _ => false end
| (AbsVar v)::r1 => match e2 with (AbsVar v2)::r2 => if beq_id v v2 then beq_absExp_list x r1 r2 else false | _ => false end
| (AbsQVar v)::r1 => match e2 with (AbsQVar v2)::r2 => if beq_nat v v2 then beq_absExp_list x r1 r2 else false | _ => false end
| ((AbsFun id1 l1)::r1) => match e2 with
((AbsFun id2 l2)::r2) => if beq_id id1 id2 then
if beq_absExp_list x l1 l2 then beq_absExp_list x r1 r2 else false else false | _ => false end
| _ => false
end.
I get the error "Error: Cannot guess decreasing argument of fix." The problem is the second to last case which handles AbsFun. I further isolated the problem to the fact that l1 and l2 are not recognized as subterms of e1 and e2. How can I work around this issue?
- Ken
match e1 with
| _ => false
end.
- Ken
- [Coq-Club] Trouble with a recursive definition, Kenneth Roe, 05/24/2012
- Re: [Coq-Club] Trouble with a recursive definition, Robbert Krebbers, 05/24/2012
- RE: [Coq-Club] Trouble with a recursive definition, Kenneth Roe, 05/29/2012
