- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: Kenneth Roe <kendroe AT hotmail.com>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Trouble with a recursive definition
- Date: Thu, 24 May 2012 16:32:57 +0200
You have to write it as a nested fixed point:
Require Import List Arith Bool.
Definition beq_list {A} (f : A -> A -> bool) : list A -> list A -> bool :=
fix go l k :=
match l, k with
| nil, nil => true
| x :: l, y :: k => f x y && go l k
| _, _ => false
end.
Definition absVar := nat.
Parameter (id ExpValue heap : Type).
Parameter (beq_id : id -> id -> bool).
Inductive absExp ( f : id -> list ExpValue -> ExpValue ) : Type :=
| AbsNatVal : nat -> absExp f
| AbsHeapVal : heap -> absExp f
| AbsVar : id -> absExp f
| AbsQVar : absVar -> absExp f
| AbsFun : id -> list (absExp f) -> absExp f.
Fixpoint beq_absExp x (e1 : absExp x) (e2 : absExp x) : bool :=
match e1 with
| AbsNatVal v => match e2 with AbsNatVal v2 => beq_nat v v2 | _ => false end
| AbsVar v => match e2 with AbsVar v2 =>beq_id v v2 | _ => false end
| AbsQVar v => match e2 with AbsQVar v2 => beq_nat v v2 | _ => false end
| AbsFun id1 l1 => match e2 with AbsFun id2 l2 => beq_id id1 id2 && beq_list (beq_absExp x) l1 l2 | _ => false end
| _ => false
end.
On 05/24/2012 04:15 PM, Kenneth Roe wrote:
I have entered the following to define an abstract expression type and a
simple equality operator between expressions:
Fixpoint beq_absExp_list x (e1 : list (absExp x)) (e2 : list (absExp x))
: bool :=
match e1 with
| nil => match e2 with nil => true | _ => false end
| (AbsNatVal v)::r1 => match e2 with (AbsNatVal v2)::r2 => if beq_nat v
v2 then beq_absExp_list x r1 r2 else false | _ => false end
| (AbsVar v)::r1 => match e2 with (AbsVar v2)::r2 => if beq_id v v2 then
| (AbsQVar v)::r1 => match e2 with (AbsQVar v2)::r2 => if beq_nat v v2
| ((AbsFun id1 l1)::r1) => match e2 with
((AbsFun id2 l2)::r2) => if beq_id id1 id2 then
if beq_absExp_list x l1 l2 then beq_absExp_list x r1 r2 else false else
| _ => false
end.
I get the error "Error: Cannot guess decreasing argument of fix." The
problem is the second to last case which handles AbsFun. I further
isolated the problem to the fact that l1 and l2 are not recognized as
subterms of e1 and e2. How can I work around this issue?
- Ken
- [Coq-Club] Trouble with a recursive definition, Kenneth Roe, 05/24/2012
- Re: [Coq-Club] Trouble with a recursive definition, Robbert Krebbers, 05/24/2012
- RE: [Coq-Club] Trouble with a recursive definition, Kenneth Roe, 05/29/2012
