- To: Bingzhou <bingzhou.zheng AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] the domain of a binary function
- Date: Mon, 28 May 2012 13:46:59 -0400
On 05/28/2012 01:33 PM, Bingzhou wrote:
1. I write the following scripts:
Definition binFn : Type := R -> R -> R.
Definition nonEmptyDomain (f: binFn): Prop :=
exists x: R, exists y: R, exists z: R, z = f x y.
This is an overly complicated definition. A proposition [nonEmptyDomain f] is true iff the type [R] has at least one element. That is, the definition of [f] doesn't matter, so you probably want to rethink your formalization.
Inductive domain (f: binFn) : Type :=
| eDom: ~nonEmptyDomain f -> domain f
| neDom: nonEmptyDomain f -> domain f.
Lemma domain_dec: forall f:binFn, domain f.
I don't think this theorem is provable without nonstandard axioms. If such a value as [domain_dec] existed, it would be easy to use it to build a halting problem oracle (set [R] equal to propositions about Turing machines), so you should ask yourself if this is really what you want to prove.
proof.
*** Declarative Mode ***
______________________________________
thesis :=
forall f : binFn, domain f
I read 11.3 Language description of Coq Reference-Manual, but I cannot
understand what "Declarative Mode" really means in this proof.
Coq has a "declarative mode" with very few users, and I don't recommend using it. Perhaps you just meant to type [Proof] instead of [proof]? Writing [proof] explicitly asks to use the declarative mode.
2. I want to write a procedure which returns different values based on if the
domain of a binary function is empty or not. I wonder if the way that I define
the domain of a binary function above is correct. If not, what should I
formalize it?
You could certainly write functions that discriminate on whether a type is empty or not, if an appropriate proof is passed in. However, I've never seen this done, so probably the most useful thing is for you to explain more context on your development, so that we can offer bigger-picture advice.
- [Coq-Club] the domain of a binary function, Bingzhou, 05/28/2012
- Re: [Coq-Club] the domain of a binary function, Adam Chlipala, 05/28/2012
- [Coq-Club] Re: the domain of a binary function, Bingzhou, 05/28/2012
- Re: [Coq-Club] Re: the domain of a binary function, Adam Chlipala, 05/28/2012
