- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re: the domain of a binary function
- Date: Mon, 28 May 2012 19:27:50 +0000 (UTC)
> You could certainly write functions that discriminate on whether a type
> is empty or not, if an appropriate proof is passed in. However, I've
> never seen this done, so probably the most useful thing is for you to
> explain more context on your development, so that we can offer
> bigger-picture advice.
Thanks Adam,
I am trying to prove some properties about the decorated interval arithmetic.
An interval can have one of five decorations: safe, defined, containing,
empty,
and ill-formed.
This system has five relations:
pSaf(f, x) : x is a nonempty subset of domain(f), and the restriction of f to
x
is continuous and bounded;
pDef(f, x) : x is a nonempty subset of domain(f);
pCon(f, x) : always true;
pEmp(f, x) : x is disjoint from domain(f) (either or both of x and domain(f)
may be empty);
pIll(f, x) : domain(f) is empty.
For a function f and an interval vector x, I should define dec(f, x), i.e. the
decoration of f over x, as:
saf: if pSaf(f, x) holds;
def: if pSaf(f, x) fails and pDef(f, x) holds;
ill: if pIll(f, x) holds;
emp: if pIll(f, x) fails and pEmp(f, x) holds;
con: otherwise.
So, I think the first step is to define predicates or relations such as
emptydomain, subsetOfDomain, continuous and bounded ...
Thanks a lot,
Bingzhou
- [Coq-Club] the domain of a binary function, Bingzhou, 05/28/2012
- Re: [Coq-Club] the domain of a binary function, Adam Chlipala, 05/28/2012
- [Coq-Club] Re: the domain of a binary function, Bingzhou, 05/28/2012
- Re: [Coq-Club] Re: the domain of a binary function, Adam Chlipala, 05/28/2012
