- From: Thomas Dinsdale-Young <td202 AT doc.ic.ac.uk>
- To: coq-club AT inria.fr
- Subject: Re: Fw: [Coq-Club] module
- Date: Tue, 12 Jun 2012 16:52:18 +0100
In
Module Program1 (Import X:HasEq).
the reason X is not a module is that HasEq is the type of a functor, rather than the type of a module. If T is a module of type Typ, then HasEq T is a module type. (T is a module that just consists of a type called t. HasEq T is the type of modules that consist of a relation eq on the type t. HasEq is the type of functors that given a module of type T produce a module with a relation eq on the type T.t.)
You may want to write something like
Module Program1 (Import T : Typ) (Import X : HasEq T).
The Import imports the namespace of the module into the current module, so you can directly reference t and eq. Otherwise, you would have to write T.t and X.eq.
Hope this helps
-- Thomas
On 12/06/2012 16:01, Patricia Peratto wrote:
Can someone explain me why in some cases one has to write
the word Import by example in
Module Type HasEq (Import T:Typ).
in module Equalities
and not in other cases?
Regards Patricia
----- Original Message -----
<mailto:sylvain.heraud AT gmail.com>
*To:* Patricia Peratto
<mailto:psperatto AT adinet.com.uy>
*Sent:* Monday, June 11, 2012 12:05 PM
*Subject:* Re: [Coq-Club] module
You have to remove the keyword Import !
Module Program1 (X:HasEq).
Sylvain
On Sun, Jun 10, 2012 at 8:03 PM, Patricia Peratto
<psperatto AT adinet.com.uy
<mailto:psperatto AT adinet.com.uy>>
wrote:
__
Forgive me by the questions I make but I'm in my
first Coq proof.
I have imported Coq.Structures.Equalities. and
below it I import a Module with
and Coq displays the message:
Error:X is not a module
but HasEq was defined in Equalities.
Regards
Patricia
- [Coq-Club] module, Patricia Peratto, 06/10/2012
- <Possible follow-up(s)>
- Fw: [Coq-Club] module, Patricia Peratto, 06/12/2012
- Re: Fw: [Coq-Club] module, Thomas Dinsdale-Young, 06/12/2012
