coq-club - [Coq-Club] [generalize]ing Dependent Types
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] [generalize]ing Dependent Types
  • Date: Tue, 12 Jun 2012 14:26:13 -0400
Hi,
I have a goal of the form
[@Build_Category ?o ?a ?b ?c ?d ?e ?f = @Build_Category ?o' ?a' ?b' ?c' ?d' ?e' ?f']
and I'd like to solve it by proving [o = o'], [a = a'], ..., in that order.  This is complicated by the fact that the type of [d], [e], and [f] depend on [c] and [b], the types of [c] and [b] depend on [a], and the type of [a] depends on [o].  I've tried [f_equal], but that tactic doesn't do anything to this goal.
In my particular goal, I can prove [o = o'] by [reflexivity], and then [subst] allows me to assert [a = a'].  I can prove [H : a = a'], but then [rewrite H] tells me that it can't abstract over the type of [a], because that leads to ill-typing.  [dependent rewrite H] tells me "Error: Cannot find a well-typed generalization of the goal that makes the proof progress."  [subst] doesn't do anything.  In the past, I've been able to fix this by [generalize f f' e e' d d'; generalize c c'; generalize b b'], and then doing [rewrite H; intros].  However, my [match goal with ... end] statement fails on [generalize c].  Coq tells me to [Set Ltac Debug] for more info, but that just causes coq/coqtop/ProofGeneral to become unresponsive when it executes the [match] statement.  I've tried [idtac c], and then manually called [generalize] on what [idtac] showed me, and that ran fine, but doesn't do what I want (it doesn't actually replace the relevant term).  I suspect this is because [c] is some complicated pattern that either [match] or [generalize] doesn't see in the other terms, but I'm not sure.
I'd like to write a tactic that automatically handles these kinds of things for me, analogous to [f_equal].  Does anyone have ideas about why [generalize] is failing, or how to get around this?
I'll try to come up with a smaller example than the one I'm using, which is huge.
Thanks!
-Jason
