- To: coq-club AT inria.fr
- Subject: [Coq-Club] Re: [generalize]ing Dependent Types
- Date: Tue, 12 Jun 2012 16:27:22 -0400
After working on it a bit more, I think the problem is that some of the variables show up as [fun foo => bar] in the definition, but show up with [foo] already replaced in the rest of the definition. Is there a version of [rewrite] which, given [(fun a => b) = (fun c => d)], replaces [fun a => b] with [fun c => d], and also replaces anything that matches [b] (with [a] wild) with [d] (plugging in the appropriate variables)?
Thanks.
-Jason
On Tue, Jun 12, 2012 at 2:26 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,I have a goal of the form[@Build_Category ?o ?a ?b ?c ?d ?e ?f = @Build_Category ?o' ?a' ?b' ?c' ?d' ?e' ?f']and I'd like to solve it by proving [o = o'], [a = a'], ..., in that order. This is complicated by the fact that the type of [d], [e], and [f] depend on [c] and [b], the types of [c] and [b] depend on [a], and the type of [a] depends on [o]. I've tried [f_equal], but that tactic doesn't do anything to this goal.In my particular goal, I can prove [o = o'] by [reflexivity], and then [subst] allows me to assert [a = a']. I can prove [H : a = a'], but then [rewrite H] tells me that it can't abstract over the type of [a], because that leads to ill-typing. [dependent rewrite H] tells me "Error: Cannot find a well-typed generalization of the goal that makes the proof progress." [subst] doesn't do anything. In the past, I've been able to fix this by [generalize f f' e e' d d'; generalize c c'; generalize b b'], and then doing [rewrite H; intros]. However, my [match goal with ... end] statement fails on [generalize c]. Coq tells me to [Set Ltac Debug] for more info, but that just causes coq/coqtop/ProofGeneral to become unresponsive when it executes the [match] statement. I've tried [idtac c], and then manually called [generalize] on what [idtac] showed me, and that ran fine, but doesn't do what I want (it doesn't actually replace the relevant term). I suspect this is because [c] is some complicated pattern that either [match] or [generalize] doesn't see in the other terms, but I'm not sure.I'd like to write a tactic that automatically handles these kinds of things for me, analogous to [f_equal]. Does anyone have ideas about why [generalize] is failing, or how to get around this?I'll try to come up with a smaller example than the one I'm using, which is huge.Thanks!-Jason
- [Coq-Club] [generalize]ing Dependent Types, Jason Gross, 06/12/2012
- Re: [Coq-Club] [generalize]ing Dependent Types, Pierre Courtieu, 06/12/2012
- [Coq-Club] Re: [generalize]ing Dependent Types, Jason Gross, 06/12/2012
