- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: Gert Smolka <smolka AT ps.uni-saarland.de>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Termination
- Date: Fri, 15 Jun 2012 10:11:39 +0200
Hello,
this is a known problem of the termination checker.
What happens is that Coq reduces the body of the fixpoint, and then checks whether all recursive calls are guarded. In your example, after reduction, the body no longer contains any recursive calls (and in particular the non-terminating call), so Coq accepts your definition.
See also:
* http://foundations.cs.ru.nl/chitchat/slides/chit-barras.pdf
A talk by Bruno Barras on the implementation of the guard condition. Slide 22 shows about the same example as below.
* http://cs.ioc.ee/~tarmo/papers/mscs04.pdf
Page 2 (last paragraph) - 4 explain the problems of the guard condition.
* http://www.lix.polytechnique.fr/coq/bugs/show_bug.cgi?id=1843
Robbert
On 06/15/2012 08:29 AM, Gert Smolka wrote:
One of our students discovered that Coq 8.3 accepts
Fixpoint foo (x : nat) : nat := (fun _ => O) (foo x).
although foo diverges under cbv.
Is this considered a bug or a feature?
(foo terminates under call by name)
Gert
- [Coq-Club] Termination, Gert Smolka, 06/15/2012
- Re: [Coq-Club] Termination, Robbert Krebbers, 06/15/2012
- Re: [Coq-Club] Termination, Pierre Boutillier, 06/15/2012
- Re: [Coq-Club] Termination, Tobias Tebbi, 06/19/2012
