coq-club - Re: [Coq-Club] Termination
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Termination
  • Date: Tue, 19 Jun 2012 22:00:29 +0200
It even badly interferes with extraction:
Definition ignore (x:nat) := 0.
Fixpoint foo (x : nat) : nat := ignore (foo x).
Extraction foo.
produces the Ocaml code
let rec foo x =
  ignore (foo x)
that obviously does not terminate.
I guess this really should be considered a bug.
(At least it cannot happen if you extract to Haskell :D )
Best,
Tobias
2012/6/15 Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
On 15/06/2012 08:29, Gert Smolka wrote:
One of our students discovered that Coq 8.3 accepts
Fixpoint foo (x : nat) : nat := (fun _ =>  O) (foo x).
although foo diverges under cbv.
Is this considered a bug or a feature?
(foo terminates under call by name)
Gert
This is definitely not a feature ! This is not really a bug either because if strong normalization is broken, weak is not. As a result, consistency remains.
In any case, it's a known but not that popular fact. (Each time I show that to someone, he can't believe its eyes, then he trys for half a day to get a closed proof of false thanks to that. None has succeed yet).
It is also one of the purpose of my proposal for a new implementation of guard condition that I formally describe and badly try to explain the motivations here : http://hal.archives-ouvertes.fr/docs/00/65/17/80/PDF/boutillier.pdf
The main purpose is to exhibit how an abstract machine that computes subterm_values instead of lambda terms could at the same time ensure strong normalization and allow to interleave "fix" and "injection" tactics (which means in CIC term accepting
fix f x := match x with |C y => fun f' => f' y end f.
The patch that implements this is in the proof reading queue of the kernel guardian for a month...
Pierre.
