- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Type-Checking partial proofs
- Date: Fri, 29 Jun 2012 07:33:45 -0400
Jason Gross wrote:
I'm trying to diagnose an "Illegal application (Type Error)" that I get on [Qed]. I'm pretty sure it comes from an implicit coercion or from a [rewrite] or from [reflexivity], but I'm not sure. Is there a way to ask Coq to see if the proof built up so far type-checks? I can use [admit. Qed.], but this only works if there are no remaining existential variables.
Here's a groaty "solution": use [instantiate] to set any well-typed values of those existentials, then use the trick you mentioned.
- [Coq-Club] Type-Checking partial proofs, Jason Gross, 06/29/2012
- Re: [Coq-Club] Type-Checking partial proofs, Pierre-Marie Pédrot, 06/29/2012
- Re: [Coq-Club] Type-Checking partial proofs, Adam Chlipala, 06/29/2012
- Re: [Coq-Club] Type-Checking partial proofs, Paolo Herms, 06/29/2012
- Re: [Coq-Club] Type-Checking partial proofs, Vladimir Voevodsky, 06/29/2012
