- From: Richard Dapoigny <richard.dapoigny AT univ-savoie.fr>
- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about universes in Coq
- Date: Sun, 01 Jul 2012 17:52:09 +0200
Le 01/07/2012 02:34, Adam Chlipala a écrit :
Richard Dapoigny wrote:Yes. What is important for us is to control (at least to be aware of) the ordering between universes. Now suppose that we remove the [Check Test x] and [Check Test y]. Normally we expect that ED and PD are not ordered (if it is a partial order). If this assumption is true, are we able to prove it?
Le 30/06/2012 00:52, Adam Chlipala a écrit :
Richard Dapoigny wrote:The point here was to check with the test whether ED and PD correspond to distinct universes which means that the universe hierarchy is a partial order (as in ECC) . If it is not the case then the hierarchy simply correspond to a total order (linear).
I have some basic question about the hierarchy of universes in Coq. Suppose that we have the following code fragment:
Definition PT := Type.
Definition ED : PT := Type.
Definition PD : PT := Type.
Print Universes.
Variable Test : ED->Prop.
Variable x : ED.
Variable y : PD.
Check Test x.
Check Test y.
We expect that the universes ED and PD are different, however, the test works for both.
Why do we expect that? The act of calling [Test] on both asserts a relationship between them.
I'm not sure what you mean by the above. Coq maintains a partial order (the universe constraint graph) that must always be concretizable to some total order, though Coq never materializes that order, to my knowledge. The [Check Test y] line just has the effect of asserting [PD <= ED] in either of these kinds of order, which leads to a constraint system that is consistent.
And the wounded skies above say
it's much too much too late.
Well, maybe we should all be praying for time.
begin:vcard fn:Richard Dapoigny n:Dapoigny;Richard email;internet:richard.dapoigny AT univ-savoie.fr tel;work:+33 450 09 65 29 tel;cell:+33 621 35 31 43 version:2.1 end:vcard
- Re: [Coq-Club] Question about universes in Coq, Adam Chlipala, 07/01/2012
- Re: [Coq-Club] Question about universes in Coq, Richard Dapoigny, 07/01/2012
