- To: Richard Dapoigny <richard.dapoigny AT univ-savoie.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about universes in Coq
- Date: Sun, 01 Jul 2012 12:39:08 -0400
Richard Dapoigny wrote:
Le 01/07/2012 02:34, Adam Chlipala a écrit :
Richard Dapoigny wrote:Yes. What is important for us is to control (at least to be aware of) the ordering between universes. Now suppose that we remove the [Check Test x] and [Check Test y]. Normally we expect that ED and PD are not ordered (if it is a partial order). If this assumption is true, are we able to prove it?
Le 30/06/2012 00:52, Adam Chlipala a écrit :
Richard Dapoigny wrote:The point here was to check with the test whether ED and PD correspond to distinct universes which means that the universe hierarchy is a partial order (as in ECC) . If it is not the case then the hierarchy simply correspond to a total order (linear).
I have some basic question about the hierarchy of universes in Coq. Suppose that we have the following code fragment:
Definition PT := Type.
Definition ED : PT := Type.
Definition PD : PT := Type.
Print Universes.
Variable Test : ED->Prop.
Variable x : ED.
Variable y : PD.
Check Test x.
Check Test y.
We expect that the universes ED and PD are different, however, the test works for both.
Why do we expect that? The act of calling [Test] on both asserts a relationship between them.
I'm not sure what you mean by the above. Coq maintains a partial order (the universe constraint graph) that must always be concretizable to some total order, though Coq never materializes that order, to my knowledge. The [Check Test y] line just has the effect of asserting [PD <= ED] in either of these kinds of order, which leads to a constraint system that is consistent.
No, I don't think you can prove unrelatedness of two universe variables. Any theorem statement that could be interpreted in this way would itself have the side effect of creating a relationship!
- Re: [Coq-Club] Question about universes in Coq, Adam Chlipala, 07/01/2012
- Re: [Coq-Club] Question about universes in Coq, Richard Dapoigny, 07/01/2012
