- To: coq-club AT inria.fr
- Subject: [Coq-Club] proving impossibility of recursive equality
- Date: Fri, 13 Jul 2012 15:34:25 +0200
Hello.
I am looking for a tactic to solve a particular problem :
I have a type for some trees, which is :
Inductive t : Set :=
| Zero : t
| Gen : A -> t
| Opp : t -> t
| Add : t -> t -> t
and I want to prove something like :
Goal forall x y, x <> Add (Opp (Opp x)) y
I hoped [discriminate] would solve it, but it does not; and I have not found anything which could help, me in the documentation.
Actually, very simple cases such as [forall x, x <> Opp x] are easily proved by [induction] and [injection]/[inversion], but the first example I gave is not.
I still managed to solve it (by constructing a function f such that the call f x, morally, does not terminate, and therefore can be typed as False), but I have to rewrite this (not so short) proof entirely for each such case I encounter (and there are many of them). Neither have I succeeding in writing it with Ltac, because it would presuppose that I could pick a pattern into the context and use it to create a new pattern matching, which is, as far as I know, not allowed.
Does somebody already dealt with that ?
(Otherwise I guess I could write a tactic in OCaml for that, but it seems to be quite complicated... :p)
I hope this list to be the right place for this kind of questions...
Thank you all.
Rémi Nollet ~
- [Coq-Club] proving impossibility of recursive equality, Rémi Nollet, 07/13/2012
- Re: [Coq-Club] proving impossibility of recursive equality, Adam Chlipala, 07/13/2012
- Re: [Coq-Club] proving impossibility of recursive equality, Rémi Nollet, 07/13/2012
- Re: [Coq-Club] proving impossibility of recursive equality, Daniel Schepler, 07/13/2012
