- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proving impossibility of recursive equality
- Date: Fri, 13 Jul 2012 16:34:28 +0200
It works perfectly. :D Thank you very much !
Rémi ~
On 13/07/2012 15:39, Adam Chlipala wrote:
Rémi Nollet wrote:
I have a type for some trees, which is :
Inductive t : Set :=
| Zero : t
| Gen : A -> t
| Opp : t -> t
| Add : t -> t -> t
and I want to prove something like :
Goal forall x y, x <> Add (Opp (Opp x)) y
I hoped [discriminate] would solve it, but it does not; and I have not
found anything which could help, me in the documentation.
I'm not aware of some hidden feature of Coq that would solve your
problem directly, but here is an instance of a general recipe you can
use for deriving such contradictions:
Fixpoint size (x : t) : nat :=
match x with
| Zero => O
| Gen _ => O
| Opp y => S (size y)
| Add y z => size y + size z
end.
Lemma size_argument : forall x y : t,
size x <> size y
-> x <> y.
congruence.
Qed.
Require Import Omega.
Goal forall x y, x <> Add (Opp (Opp x)) y.
intros; apply size_argument; simpl; omega.
Qed.
- [Coq-Club] proving impossibility of recursive equality, Rémi Nollet, 07/13/2012
- Re: [Coq-Club] proving impossibility of recursive equality, Adam Chlipala, 07/13/2012
- Re: [Coq-Club] proving impossibility of recursive equality, Rémi Nollet, 07/13/2012
- Re: [Coq-Club] proving impossibility of recursive equality, Daniel Schepler, 07/13/2012
