- To: Tom Prince <tom.prince AT ualberta.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Universe Polymorphism?
- Date: Tue, 24 Jul 2012 16:41:35 -0400
Thanks!
If what you mean by "not actually effective" is the comment at the bottom of
http://www.lix.polytechnique.fr/coq/bugs/show_bug.cgi?id=2298, it seems like it was at least partially effective. For example, when I build coq at the revision right before that revert, I can do
Set Printing Universes.
Polymorphic Definition foo (a : Type) := a.
Definition foo' (a : Type) := a.Check foo. (* Type (* Top.1 *) -> Type (* Top.1 *) *)
Check foo'.(* Type (* Top.23 *) -> Type (* Top.23 *) *)
Check foo nat. (* Set *)
Check foo' nat. (* Set *)However, in Coq 8.4beta2, I get [Type (* Top.1 *) -> Type (* Top.1 *)] for [foo'], but I get [Type (* Top.1 *)] for [foo' nat].
I can imitate the sort-polymorphic behavior using
Record foo' (a : Type) := { foo'_Member : a }.
(and for definitions where the head of the body is a global class, rather than a passed argument, I can use [:>] instead of [:] and get something closer to the functionality that I want).
It's not clear to me that the test listed in that bug report is a good test of sort-polymorphic definitions that conform to existing sort-polymorphic behavior in Coq; when I translate that example to [Record] syntax, I get
Inductive paths {A:Type} : A -> A -> Type :=
idpath : forall x : A, (paths x x).
Record is_contr (A:Type) := { is_contr_ :> {x : A & forall y : A, (paths y x)} }.
Record is_prop (A:Type):= { is_prop_ :> forall (x y:A), is_contr (paths x y) }.
Record is_set (A:Type):= { is_set_ :> forall (x y:A), is_prop (paths x y) }.
Record hProp:={ hProp_ :> (sigT is_prop) }.
Check (is_set hProp).
and the last line of this gives me a universe inconsistency, too.
Was there some other problem with it?
-Jason
On Sat, Jul 21, 2012 at 1:03 AM, Tom Prince <tom.prince AT ualberta.net> wrote:
Jason Gross <jasongross9 AT gmail.com> writes:coq has for a long time had a limited support for universe polymorphism
> Hi,
> I noticed that Coq seems to have had universe polymorphism at one point,
> but no longer does (see commit message at the bottom of the message). Is
> there somewhere that I can find an explanation of why this was removed, or
> can someone respond with an explanation? (If it was discussed on coq-club
> before, are there archives of coq-club@, and can someone point me to them?)
for inductive types. The commit you reference was an attempt at adding
more support, but it wasn't actually effective (hence the revert).
Tom
- [Coq-Club] Universe Polymorphism?, Jason Gross, 07/21/2012
- Re: [Coq-Club] Universe Polymorphism?, Tom Prince, 07/21/2012
- Re: [Coq-Club] Universe Polymorphism?, Jason Gross, 07/24/2012
- Re: [Coq-Club] Universe Polymorphism?, Tom Prince, 07/26/2012
- Re: [Coq-Club] Universe Polymorphism?, Jason Gross, 07/26/2012
- Re: [Coq-Club] Universe Polymorphism?, Valentin ROBERT, 07/21/2012
