coq-club - Re: [Coq-Club] Universe Polymorphism?
  • To: Tom Prince <tom.prince AT ualberta.net>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Universe Polymorphism?
  • Date: Thu, 26 Jul 2012 01:11:11 -0400
If/when you have time, if you don't mind, I'd appreciate an example.  I tried the following, which was the first thing that came to mind when you said "partial application", but it behaved as expected:
  Polymorphic Definition typeof {A : Type} (_ : A) := A.
  Polymorphic Definition typeof' := @typeof.
  Check @typeof. (* forall A : Type (* Top.7 *), A -> Type (* Top.7 *) *)
  Check @typeof'. (* forall A : Type (* Top.7 *), A -> Type (* Top.7 *) *)
  Definition typeofnat := @typeof nat.
  Check typeofnat. (* nat -> Set *)
I tested a similar thing with two type arguments, and only giving it one of them, and it still worked.
Thanks.
-Jason
On Thu, Jul 26, 2012 at 12:34 AM, Tom Prince <tom.prince AT ualberta.net> wrote:
Jason Gross <jasongross9 AT gmail.com> writes:
> Was there some other problem with it?
It has been a long time since I looked at this, and I don't have time to
test it now, but vaguely recall that the issue is that partial
application (which is the only type of application) loses the
polymorpism.
  Tom
