- From: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Extraction with OCaml strings
- Date: Wed, 25 Jul 2012 10:22:51 -0400
Does someone have an example of an OCaml program extracted from Coq that
illustrates the "correct" way to extract the Coq string type? I've been able
to use the code below (cribbed from Coq.extraction.ExtrOcamlString) to get
something minimally working, but the embedded comments suggest that there
ought to be a better way.
Thanks,
- Benjamin
Require Import Ascii String.
Extract Inductive ascii => char
"(* If this appears, you're using Ascii internals. Please don't *) (fun
(b0,b1,b2,b3,b4,b5,b6,b7) -> let f b i = if b then 1 lsl i else 0 in Char.chr
(f b0 0 + f b1 1 + f b2 2 + f b3 3 + f b4 4 + f b5 5 + f b6 6 + f b7 7))"
"(* If this appears, you're using Ascii internals. Please don't *) (fun f c
-> let n = Char.code c in let h i = (n land (1 lsl i)) <> 0 in f (h 0) (h 1)
(h 2) (h 3) (h 4) (h 5) (h 6) (h 7))".
Extract Constant zero => "'\000'".
Extract Constant one => "'\001'".
Extract Constant shift =>
"fun b c -> Char.chr (((Char.code c) lsl 1) land 255 + if b then 1 else 0)".
Extract Inlined Constant ascii_dec => "(=)".
- [Coq-Club] Extraction with OCaml strings, Benjamin C. Pierce, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, Paolo Herms, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, Benjamin C. Pierce, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, AUGER Cédric, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, Xavier Leroy, 07/31/2012
