- From: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- To: Paolo Herms <paolo.herms AT cea.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Extraction with OCaml strings
- Date: Wed, 25 Jul 2012 12:01:01 -0400
Many thanks!
One follow-up question: If I do
Require ExtrOcamlString.
I get an error like this when compiling the generated OCaml code:
Error: This expression has type 'a list/9
but an expression was expected of type char list/1045
On the other hand, if I inline the contents of ExtrOcamlString, this error
disappears and things work perfectly.
Any idea why?
- Benjamin
On Jul 25, 2012, at 11:02 AM, Paolo Herms wrote:
> No that's the good way of extracting characters.
> It is a hard-coded in the extraction plugin that if there is a binding from
> Coq ascii to OCaml char, then a Coq ascii like
> Ascii true false false false false true true false
> will be extracted to the OCaml char 'a'.
> Try it:
> Open Scope char_scope.
> Definition a := "a".
> Extraction a.
> So the comments that bothered you won't appear by extraction, unless you do
> pattern matching on some asciis in your Coq code.
> That's for the character type. For the string type, it would be dangerous
> to
> extract it to OCaml strings, as these are mutable, so you should stick with
> the extraction to lists of chars.
> Paolo Herms
> PhD Student - CEA Software Safety Lab. / Inria ProVal project-team
> Paris, France
> On Wednesday 25 July 2012 16:23:07 Benjamin C. Pierce wrote:
>> Does someone have an example of an OCaml program extracted from Coq that
>> illustrates the "correct" way to extract the Coq string type? I've been
>> able to use the code below (cribbed from Coq.extraction.ExtrOcamlString) to
>> get something minimally working, but the embedded comments suggest that
>> there ought to be a better way.
>> Thanks,
>> - Benjamin
>> Require Import Ascii String.
>> Extract Inductive ascii => char
>> "(* If this appears, you're using Ascii internals. Please don't *) (fun
>> (b0,b1,b2,b3,b4,b5,b6,b7) -> let f b i = if b then 1 lsl i else 0 in
>> Char.chr (f b0 0 + f b1 1 + f b2 2 + f b3 3 + f b4 4 + f b5 5 + f b6 6 + f
>> b7 7))" ]
>> "(* If this appears, you're using Ascii internals. Please don't *) (fun f c
>> -> let n = Char.code c in let h i = (n land (1 lsl i)) <> 0 in f (h 0) (h
>> 1) (h 2) (h 3) (h 4) (h 5) (h 6) (h 7))". Extract Constant zero =>
>> "'\000'".
>> Extract Constant one => "'\001'".
>> Extract Constant shift =>
>> "fun b c -> Char.chr (((Char.code c) lsl 1) land 255 + if b then 1 else
>> 0)".
>> Extract Inlined Constant ascii_dec => "(=)".
- [Coq-Club] Extraction with OCaml strings, Benjamin C. Pierce, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, Paolo Herms, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, Benjamin C. Pierce, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, AUGER Cédric, 07/25/2012
- Re: [Coq-Club] Extraction with OCaml strings, Xavier Leroy, 07/31/2012
