- From: "gallais @ ensl.org" <guillaume.allais AT ens-lyon.org>
- To: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Simplest example of impredicative Prop?
- Date: Wed, 25 Jul 2012 15:38:02 +0100
Would « being extensional is an extensional concept » fit the bill?
If you're talking about predicates on functions then Prop's
impredicativity lets you apply the concept to itself and prove that,
indeed, being extensional is extensional.
Definition prop_extensional (A B : Type) (P : (A -> B) -> Prop) : Prop :=
forall f g, (forall (a : A), f a = g a) -> P f -> P g.
Lemma prop_extensional_is_prop_extensional : forall A B,
prop_extensional (A -> B) Prop (prop_extensional A B).
Proof.
intros A B P Q eqPQ Pext f g eqfg.
do 2 rewrite <- eqPQ.
apply Pext.
exact eqfg.
Qed.
But if you try to play the same game with [P] targetting Type, you end
with a universe inconsistency.
Definition type_extensional (A B : Type) (P : (A -> B) -> Type) : Type :=
Lemma type_extensional_is_type_extensional : forall A B,
type_extensional (A -> B) Type (type_extensional A B).
Proof.
apply Pext.
exact eqfg.
Qed. (* Qed. fails *)
Cheers,
guillaume
On 25 July 2012 15:23, Benjamin C. Pierce
wrote:
> What is the most elementary example showing why we want Prop to be
> impredicative?
> Thanks!
> - Benjamin
- [Coq-Club] Simplest example of impredicative Prop?, Benjamin C. Pierce, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Adam Chlipala, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, gallais @ ensl.org, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Chung-Kil Hur, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Arnaud Spiwack, 07/27/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Bas Spitters, 07/30/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Arnaud Spiwack, 07/31/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Benjamin C. Pierce, 07/31/2012
