- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: "Benjamin C. Pierce" <bcpierce AT cis.upenn.edu>
- Cc: Bas Spitters <spitters AT cs.ru.nl>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Simplest example of impredicative Prop?
- Date: Tue, 31 Jul 2012 19:13:47 +0200
Yes: the usual proof uses an impredicative Prop, but Wilander's only uses strong elimination of the boolean type. They're essentially the same proof, though.
On 31 July 2012 17:07, Benjamin C. Pierce <bcpierce AT cis.upenn.edu> wrote:
Very interesting. Just to check: this is saying that we need a universe *instead of* impredicative Prop for this example?- BOn Jul 31, 2012, at 3:16 AM, Arnaud Spiwack wrote:Mmm, very clever.
My bad then. I'll have to retract my example.On 30 July 2012 15:40, Bas Spitters <spitters AT cs.ru.nl> wrote:
> surjectivity is equivalent to being epi in the category of setoidsYou need at least a universe to prove this statement:
http://www2.math.uu.se/research/pub/Wilander2.pdf
but if you have a universe the statement can be proved.
Bas
- [Coq-Club] Simplest example of impredicative Prop?, Benjamin C. Pierce, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Adam Chlipala, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, gallais @ ensl.org, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Chung-Kil Hur, 07/25/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Arnaud Spiwack, 07/27/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Bas Spitters, 07/30/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Arnaud Spiwack, 07/31/2012
- Re: [Coq-Club] Simplest example of impredicative Prop?, Benjamin C. Pierce, 07/31/2012
