coq-club - [Coq-Club] Proof irrelevance for nat.le
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Proof irrelevance for nat.le
  • Date: Tue, 31 Jul 2012 17:32:38 -0700
Speaking of proof irrelevance for le... I have a suggestion for an
improved solution to http://coq.inria.fr/faq entry 138.
Require Import Eqdep_dec.
Require Import Eqdep.
Require Import Arith.
Scheme le_ind' := Induction for le Sort Prop.
Lemma le_uniqueness : forall (m n:nat) (le1 le2 : m <= n), le1 = le2.
Proof.
cut (forall (m n:nat) (le1 : m <= n) (n':nat) (le2 : m <= n'),
n = n' -> eq_dep _ (le m) n le1 n' le2).
intros.
apply eq_dep_eq_dec.
exact eq_nat_dec.
apply H; trivial.
induction le1 using le_ind'; destruct le2.
constructor.
intro.
contradict le2.
subst.
apply le_Sn_n.
intro.
clear IHle1; contradict le1.
subst.
apply le_Sn_n.
injection 1.
intro.
apply IHle1 with (le2 := le2) in H0.
destruct H0.
constructor.
Qed.
Print Assumptions le_uniqueness. (* Closed under the global context *)
(Here I've tried to stick to simple tactics instead of doing what I'd
usually do and combining them more.)
Daniel Schepler
  • [Coq-Club] Proof irrelevance for nat.le, Daniel Schepler, 08/01/2012
