- From: Alan Schmitt <alan.schmitt AT polytechnique.org>
- To: coq-club AT inria.fr
- Cc:
- Subject: Re: [Coq-Club] Extraction with OCaml strings
- Date: Wed, 01 Aug 2012 14:27:16 +0200
Xavier Leroy
<Xavier.Leroy AT inria.fr>
writes:
> Floats would be next, using Flocq on Coq's side.
The following is a quick and dirty way to extract floats from Flocq. I'm
sure there are much nicer and safer ways to do it.
(* number *)
Require Import ExtrOcamlZInt.
Extract Inductive Fappli_IEEE.binary_float => float [
"(fun s -> if s then (0.) else (-0.))"
"(fun s -> if s then infinity else neg_infinity)"
"nan"
"(fun (s, m, e) -> let f = ldexp (float_of_int m) e in if s then f else
-.f)"
Extract Constant number_comparable => "(=)".
Extract Constant number_add => "(+.)".
Extract Constant number_mult => "( *. )".
Extract Constant number_div => "(/.)".
Extract Constant number_of_int => float_of_int.
(* The following functions make pattern matches with floats and will thus be
removed. *)
Extraction Inline Fappli_IEEE.Bplus Fappli_IEEE.binary_normalize
Fappli_IEEE_bits.b64_plus.
Extraction Inline Fappli_IEEE.Bmult Fappli_IEEE.Bmult_FF
Fappli_IEEE_bits.b64_mult.
Extraction Inline Fappli_IEEE.Bdiv Fappli_IEEE_bits.b64_div.
Alan
- Re: [Coq-Club] Extraction with OCaml strings, Alan Schmitt, 08/01/2012
