- From: Kristopher Micinski <krismicinski AT gmail.com>
- To: Aleks Nanevski <aleks.nanevski AT imdea.org>, coq club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] reasoning out of type equalities
- Date: Sat, 4 Aug 2012 13:58:52 -0400
Forgot the list..
On Aug 4, 2012 1:36 PM, "Kristopher Micinski" <krismicinski AT gmail.com> wrote:
Remember, = is notation for eq, and eq_refl is defined inductively only on elements of the same type (those you can demonstrate are convertible), there are alternative encodings of equality you might look into, however (setoids, for example), depending on your needs.
Kris (on a phone)
On Aug 4, 2012 1:19 PM, "Aleks Nanevski" <aleks.nanevski AT imdea.org> wrote:Hi,
Given a nonempty type B, I was wondering if the following is provable:
forall A1 A2 : Type, A1 * B = A2 * B -> A1 = A2
Thanks,
Aleks
- [Coq-Club] reasoning out of type equalities, Aleks Nanevski, 08/04/2012
- Message not available
- Re: [Coq-Club] reasoning out of type equalities, Kristopher Micinski, 08/04/2012
- Re: [Coq-Club] reasoning out of type equalities, Chung-Kil Hur, 08/04/2012
- Re: [Coq-Club] reasoning out of type equalities, Vladimir Voevodsky, 08/04/2012
- Re: [Coq-Club] reasoning out of type equalities, Aleksandar Nanevski, 08/05/2012
- Re: [Coq-Club] reasoning out of type equalities, andré hirschowitz, 08/05/2012
- Re: [Coq-Club] reasoning out of type equalities, Vladimir Voevodsky, 08/05/2012
- Re: [Coq-Club] reasoning out of type equalities, Adam Chlipala, 08/05/2012
