- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] sigma types in category theory
- Date: Mon, 6 Aug 2012 11:47:17 +0200
The keyword you seem to be looking for is fibration or fibred category. Thomas Streicher has a long writeup www.mathematik.tu-darmstadt.de/~streicher/FIBR/FibLec.pdf . You might find it useful.
Arnaud
On 6 August 2012 02:34, Jason Gross <jasongross9 AT gmail.com> wrote:
Hi,I'm working on Coqing category theory, and found that I needed the same construction/proofs for comma categories and for (op)lax slice categories, and thought that I'd get a better logical separation of code if I generalized [sigT] to categories. I have mostly done this (code available, for now, at https://dl.dropbox.com/u/11313181/Temp/sigCat.zip and https://dl.dropbox.com/u/11313181/Temp/sigCat/sigCategory.v, if anyone wants to see what I've done so my questions make more sense). I defined a category where objects and morphisms are each a sigma type of the original morphisms and objects of the category. I "discovered" that [sig] corresponds to full subcategories, wide subcategories, and subcategories when done on the objects, morphisms, and both, respectively. The product category, and the projection functors, correspond to [prod], [fst] and [snd], which I know are the non-dependent versions of [sigT]. Do dependently typed sigma categories exist anywhere in the literature? Wikipedia (http://en.wikipedia.org/wiki/Intuitionistic_type_theory#Categorical_models_of_type_theory) suggests that they might be "categories with families", though I don't really understand the correspondence in that part. I've defined the functor analogue of [projT1], but I am stumped on the analogue of [projT2]. Does it exist? (Does it exist with my formulation of [sigT] categories, or only more specific/general ones?)Thanks.-Jason
- [Coq-Club] sigma types in category theory, Jason Gross, 08/06/2012
- Re: [Coq-Club] sigma types in category theory, Arnaud Spiwack, 08/06/2012
- Re: [Coq-Club] sigma types in category theory, Eduardo Ochs, 08/07/2012
- Re: [Coq-Club] sigma types in category theory, Michael Shulman, 08/07/2012
