- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] non-failing version of [change _ with _ in *]?
- Date: Mon, 6 Aug 2012 08:08:42 -0400
Hi,
Is there a variant of [change _ with _ in *] that does not fail if [change _ with _ in H] fails for some particular hypothesis, but succeeds for all the other ones? I've constructed a tactic that has the behavior I want, but it seems somewhat hacky, and I'm wondering if anyone has or knows of a better solution. The first two [change] attempts in the following code fail, while the third one has the tactic I made/the behavior I'm looking for. Thanks.
Definition first (a b : Type) := a.
Goal forall a b c d (a' := first a b) (b' := first c d), a = b -> False.
intros.
(* change a with (first a' a) in *. *) (* Error: Cannot create self-referring hypothesis a' *)
(* repeat match goal with
| [ H : _ |- _ ] => progress change a with (first a' a) in H |- *
end. *) (* loops forever *)
Local Ltac do_for_each_hyp' tac fail_if_seen :=
match goal with
| [ H : _ |- _ ] => fail_if_seen H; tac H; try do_for_each_hyp' tac ltac:(fun H' => fail_if_seen H'; match H' with | H => fail 1 | _ => idtac end)
end.
Local Ltac do_for_each_hyp tac := do_for_each_hyp' tac ltac:(fun H => idtac).
change a with (first a' a); do_for_each_hyp ltac:(fun H => change a with (first a' a) in H).
-Jason
- [Coq-Club] non-failing version of [change _ with _ in *]?, Jason Gross, 08/06/2012
- Re: [Coq-Club] non-failing version of [change _ with _ in *]?, Adam Chlipala, 08/06/2012
