coq-club - Re: [Coq-Club] eta(?) conversion in records?
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] eta(?) conversion in records?
  • Date: Mon, 27 Aug 2012 12:52:49 +0200
Hello Jason,
On 18.08.12 6:58 PM, Jason Gross wrote:
Hi,
I have two related questions:
Given a record like
Record foo := { bar : Type }.
(or a more complicated one with arguments and multiple fields, or
possibly even any inductive type with one constructor which lives in
[Type]),
Agda has eta-conversion for records. There are no theoretical problems, it can be dealt with in type checking, unification [Norell PhD; Abel/Pientka TLCA 2011], and semantic models [Abel/Coquand FundInf 2007].
However, adding eta-conversion for inductive types with just one constructor may break termination. Here is a hypothetical case:
data Empty : Set where
c : (d : Empty) -> Empty
f : Empty -> Empty
f (c x) = c (f x)
f is structurally recursive, however, we have
f x = f (c (d x)) = c (f (d x)) = c (f (c (d (d x)))) = c (c (f (d (d x))))
You see where this leads to...
In particular, we do not want eta for the type Acc...
Cheers,
Andreas
First, would it break CIC (or cause any other problems) if [f : foo]
were made convertible with [Build_foo (bar f) : foo]? (Is this properly
named "eta conversion of records", or is it called something else?) I
suspect it wouldn't cause any problems, because I can always do
something like
let t := fresh in destruct f as [ t ];
change (Build_foo (bar (Build_foo t))) with (Build_foo t) in *;
set (f := Build_foo t) in *;
clearbody f; clear t.
in any proof in which I want [f] and [Build_foo (bar f)] to be
convertible. Admittedly, this adds an extra [match] in the
proof/construction, but I don't think this is a big deal, because I
think we can always "get rid "of the match by [destruct f] in any
proof/construction (that is, after [intros], we can always move the
match up to top level, I think).
However, I'm not completely confident in my argument, because I know
that allowing this kind of match-less conversion on inductive types not
in [Type] (such as [@eq]) leads to ill-typed terms and being able to
prove proof irrelevance.
Second: Assuming that this would not cause problems, are there any plans
to add this to Coq?
Thanks.
-Jason
Andreas Abel <>< Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
