- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] eta(?) conversion in records?
- Date: Tue, 28 Aug 2012 15:34:02 +0200
Le 28 août 2012 à 14:28, Adam Chlipala a écrit :
> On 08/28/2012 08:27 AM, Matthieu Sozeau wrote:
>> η for (non-recursive) records will come along with a more efficient
>> representation for projections which will not carry parameters anymore (as
>> in Agda too).
> This sounds a little scary from a trusted-code-base-size perspective. Does
> the proof checker need to get more complex to support your addition?
Nope, there is only less work to do. Compare:
In current Coq, when typechecking [proj params record]: infer the type of
[proj], typecheck params against the returned product type (and substitute at
the same time), typecheck record against the expected type. When I say
typecheck it means infer type and convert to the expected type.
Now we would have [record.(proj)]: Typecheck record and put in hnf: it has to
be of the form Ind params. Directly substitute (record, params) in the
(safe,trusted) type of the projection, you're done. Projections become a
particular kind of constants in this design and they're always applied to a
record. This makes the rest of the code (reduction, conversion) easier to
adapt than trying to keep projection names as regular constants and treat the
projection case as a subcase of regular application. Plus you'll never see it
reduced to [match foo with Record _ _ _ _ _ _ _ _ _ _ _ _ bar => bar end].
Code-size-wise (of the TCB) it is a very small change.
Cheers,
-- Matthieu
- [Coq-Club] eta(?) conversion in records?, Jason Gross, 08/18/2012
- Re: [Coq-Club] eta(?) conversion in records?, Andreas Abel, 08/27/2012
- Re: [Coq-Club] eta(?) conversion in records?, Matthieu Sozeau, 08/28/2012
- Re: [Coq-Club] eta(?) conversion in records?, Adam Chlipala, 08/28/2012
- Re: [Coq-Club] eta(?) conversion in records?, Ryan Wisnesky, 08/28/2012
- Re: [Coq-Club] eta(?) conversion in records?, Andrew Cave, 08/28/2012
