- From: frank maltman <frank.maltman AT googlemail.com>
- To: AUGER Cédric <sedrikov AT gmail.com>
- Cc: <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Data structure invariant problem
- Date: Thu, 30 Aug 2012 18:42:40 +0000
On Thu, 30 Aug 2012 20:34:45 +0200
AUGER Cédric
wrote:
> Le Thu, 30 Aug 2012 17:55:18 +0000,
> frank maltman
> a écrit :
> > Could someone please explain what's going on here?
> Run the following to understand where your n0 comes from :
> Definition insert_node_create_frequency
> (c : cache)
> (n : node)
> (H_name : ~Name_Maps.In (node_name n) (cache_name_map c))
> (H_freq : ~Node_Maps.In (node_frequency n) (cache_frequency_map c))
> : insertion.
> refine (match insert_maps_node (cache_frequency_map c) (cache_name_map
> c) n H_name H_freq with
> | (exist node_m H_node_add, exist name_m H_name_add) =>
> let ci := _ in
> Insertion {|cache_frequency_map := node_m;
> cache_name_map := name_m;
> cache_invariant := ci|} n _
> end).
> clear s s0.
> (** Check the head of your goal, and you'll find your [n0] *)
I see, that makes sense. Thanks.
- [Coq-Club] Data structure invariant problem, frank maltman, 08/30/2012
- Re: [Coq-Club] Data structure invariant problem, AUGER Cédric, 08/30/2012
- Re: [Coq-Club] Data structure invariant problem, frank maltman, 08/30/2012
- Re: [Coq-Club] Data structure invariant problem, gallais @ ensl.org, 08/30/2012
