coq-club - [Coq-Club] type class instance resolution
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: [Coq-Club] type class instance resolution
  • Date: Fri, 31 Aug 2012 01:11:29 -0700
Hi Coq Clubbers,
I have been trying to gain proficiency with type classes and instance resolution in Coq and have been fairly successful, that is, until I started to try to use notations with my type classes via the "operational type class" technique as described, for example, in Pierre Castéran and Matthieu Sozeau's recent tutorial.
Below is a small example illustrating the kind of problems I've been having. I would be grateful if someone could explain to me why the tactic in the last line doesn't succeed. I'm sure it's something silly that I'm misunderstanding but, well, I couldn't figure it out.
----------8<----------
Require Import Utf8 ZArith .
Generalizable All Variables .
Obligation Tactic := eauto 10 with arith .
(* an "operational type class" for binary relations to support infix notation *)
Class Binary_Relation (A : Type) : Type :=
binary_relation : A → A → Prop .
Hint Unfold Binary_Relation .
Hint Unfold binary_relation .
Infix "∙" := binary_relation (at level 61 , left associativity) .
Instance relations_are_relations `(R : A → A → Prop) : Binary_Relation A :=
binary_relation := R
Print Instances Binary_Relation .
(* some properties that binary relations could have *)
Class Reflexive `(R : Binary_Relation A) : Prop :=
reflexivity : ∀ (x : A) , x ∙ x .
Hint Unfold Reflexive .
Class Transitive `(R : Binary_Relation A) : Prop :=
transitivity : ∀ (x y z : A) , x ∙ y → y ∙ z → x ∙ z .
Hint Unfold Transitive .
(* etc. *)
(* a preorder is a reflexive and transitive relation *)
Class Preorder `(R : Binary_Relation A) : Prop :=
preorder_reflexivity :> Reflexive R
preorder_transitivity :> Transitive R
Hint Constructors Preorder .
(* test out the notation: *)
Goal ∀ `(P : Preorder A) (x y z : A ) , x ∙ y → y ∙ z → x ∙ z .
Proof .
intros .
eapply transitivity.
- eassumption .
- assumption .
Qed .
(* so far, so good *)
(* notice that ≤ is a preorder on nat: *)
Program Instance le_preorder : Preorder le .
Obligations (* seems okay *) .
(* since it's a preorder it should be reflexive too, right? *)
Goal Reflexive le .
Proof .
unfold Reflexive .
apply reflexivity .
(* Error:
* Could not find an instance for "Reflexive le".
* but why not? (Reflexive le) should be satisfied by (Preorder le),
* which Coq figured out all by itself, so why can't it infer (Reflexive le)?
---------->8----------
I thought that maybe it wasn't getting that le is a binary relation on nat, but adding the line:
Instance le_relation : Binary_Relation nat := le .
doesn't help either.
thanks in advance for any help,
-Ed
