- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] type class instance resolution
- Date: Fri, 31 Aug 2012 11:29:19 +0200
Le Fri, 31 Aug 2012 01:11:29 -0700,
Ed Morehouse
<emorehouse AT wesleyan.edu>
a écrit :
> Hi Coq Clubbers,
> I have been trying to gain proficiency with type classes and instance
> resolution in Coq and have been fairly successful, that is, until I
> started to try to use notations with my type classes via the
> "operational type class" technique as described, for example, in
> Pierre Castéran and Matthieu Sozeau's recent tutorial.
> Below is a small example illustrating the kind of problems I've been
> having. I would be grateful if someone could explain to me why the
> tactic in the last line doesn't succeed. I'm sure it's something
> silly that I'm misunderstanding but, well, I couldn't figure it out.
> ----------8<----------
> (* since it's a preorder it should be reflexive too, right? *)
> Goal Reflexive le .
> Proof .
> unfold Reflexive .
> apply reflexivity .
It works if you declare [le] as an instance of a binary relation :
Instance le_bin_rel : Binary_Relation nat := le.
Goal Reflexive le_bin_rel.
Proof .
unfold Reflexive .
apply reflexivity.
> (* Error:
> * Could not find an instance for "Reflexive le".
> * but why not? (Reflexive le) should be satisfied by (Preorder le),
> * which Coq figured out all by itself, so why can't it infer
> (Reflexive le)?
> ---------->8----------
> I thought that maybe it wasn't getting that le is a binary relation
> on nat, but adding the line:
> Instance le_relation : Binary_Relation nat := le .
> doesn't help either.
> thanks in advance for any help,
> -Ed
- [Coq-Club] type class instance resolution, Ed Morehouse, 08/31/2012
- Re: [Coq-Club] type class instance resolution, AUGER Cédric, 08/31/2012
