coq-club - Re: [Coq-Club] Prenex form
  • From: Gregory Malecha <gmalecha AT eecs.harvard.edu>
  • To: Ryan Wisnesky <ryan AT cs.harvard.edu>
  • Cc: Marko Maliković <marko AT ffri.hr>, coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Prenex form
  • Date: Tue, 4 Sep 2012 10:00:18 -0400
Hi --
Is this guaranteed when you have dependent types? You could try to pull apart the dependency, but it isn't clear to me that it is always possible.
Inductive IsEven : nat -> Type :=
| Pf : forall n, Even n -> IsEven n.
forall x : nat, Even x -> exists y : IsEven x, True
What would be the prenex form for this? You can't move the existential before the "Even x". It seems like you would need a way to pull dependency out of values, or treat -> as forall (does that defeat the purpose? I don't know).
On Mon, Sep 3, 2012 at 10:08 PM, Ryan Wisnesky <ryan AT cs.harvard.edu> wrote:
Such a conversion could be non-trivial in that to avoid reifying the syntax of Prop, it would probably need to be a tactic (although you could use explicit syntax), and regardless, it would require heavy use of a classical logic axiom or a decidable domain.  It would be pretty useful though, so I hope it exists.
On Sep 3, 2012, at 6:20 PM, Marko Maliković <marko AT ffri.hr> wrote:
> Regards,
> Is there module for conversion first-order formulas over the Prop into
> Prenex form. I can not find it.
> Great thanks,
> Dr. Sc. Marko Maliković
> Docent
> Filozofski fakultet
> Sveučilište u Rijeci
> Ph.D. Marko Maliković
> Assistant Professor
> Faculty of Humanities and Social Sciences
> University of Rijeka, Croatia
> marko.malikovic AT ffri.hr
> http://www.ffri.hr/~marko
gregory malecha
http://www.people.fas.harvard.edu/~gmalecha/
